New clutch suggestions...
Old Feb 9, 2008 | 10:20 PM
ChuckX182's Avatar
Thinking about getting a new clutch, flywheel etc. What do you guys recommend? I'm just curious what's out there and what would be a good one. I was looking at Exedy and saw a few different ones.
Old Feb 9, 2008 | 10:24 PM
R&C_rallySS's Avatar
If you drive a SS/SC. I would suggest a Exedy Clutch and flywheel package. Awesome mod.
Old Feb 9, 2008 | 10:25 PM
forced_induction's Avatar
im looking around for one too and most people recommend the exedy stage 3, heres the cheapest i found them for... http://www.cobaltperformanceparts.co...lutch_Kit.html
Old Feb 9, 2008 | 11:21 PM
Sharkey's Avatar
make sure before you order from them that you check out their forum section on this site (in the vendor section). check out the recent posts about them.....
jeremie's Avatar
exedy.
Old Feb 9, 2008 | 11:38 PM
ChuckX182's Avatar
What's the difference between the single plate clutch and the multi-plate clutch?
Old Feb 9, 2008 | 11:42 PM
rallyracer's Avatar
x2...im lost.
Old Feb 10, 2008 | 12:00 AM
Sharkey's Avatar
a single plate clutch has one disk, a multi-plate would have 2 or more disks. a multi disk clutch is used when you make a lot of torque and need a clutch thats still drivable.
for a cobalt, a multi plate clutch isnt needed, the single disk clutches out are more than up to the task of holding the power we can put through our transmission.
Old Feb 10, 2008 | 10:23 AM
ChuckX182's Avatar
Cool, thanks for the explanation. I'll prolly end up going with Exedy. There is a Bully clutch on ebay starting at $100. How are those?
Old Feb 10, 2008 | 10:42 AM
2K5SS/SC?'s Avatar
Just get the Exedy one and be done. Far superior to all other clutches for our cars. Trust me as I have been through all the Clutchmasters **** and finally ended up with the Exedy Hypersingle kit. It is nothing short of badass! Just be sure to get a new slave cylinder while you're at it! If you don't replace it, it will fail on you!
Old Feb 10, 2008 | 10:50 AM
rallyracer's Avatar
Where's the best place to get one of these?
Old Feb 10, 2008 | 11:10 AM
ChuckX182's Avatar
Cool, thanks for the heads up!
Old Feb 11, 2008 | 12:18 PM
TurboTechRacing's Avatar
Exedy Hyper Single (includes both the clutch kit and a flywheel)
OR
SPEC stage 3+ and SPEC aluminum Flywheel.
We carry them at www.TurboTechRacing.com PM us with questions.
Old Feb 11, 2008 | 12:44 PM
rallyracer's Avatar
I was unable to locate the Exedy HS on your site.
Old Feb 11, 2008 | 01:29 PM
qwikredline's Avatar
stock is good Exedy is super good
Old Feb 11, 2008 | 01:39 PM
Rangerondubz's Avatar
::smacks you::
Linkage
Old Feb 11, 2008 | 01:42 PM
firestorm's Avatar
i dissagree, exedy is far too pretty to lock inside the housing. its sacralidge.
mine still sits in a box, til late this wee/early next week install. i pay it my respects daily.
Old Feb 11, 2008 | 01:50 PM
Originally Posted by Rangerondubz
::smacks you::
Linkage
Thanks for providing the link.
Old Feb 11, 2008 | 02:04 PM
CobaltSS 16's Avatar
From what ive heard, exedy is the best...
Old Feb 11, 2008 | 02:21 PM
06BrandonSS's Avatar
Whats everyones opinion on the Exedy OEM replacement clutch with my stage 2 and 2.9 pulley mods? I know it doesn't have everything the higher dollar clutches have, but thats about all I can afford at this time. I heard its actually better and holds up better than the factory clutch.
Old Feb 11, 2008 | 02:23 PM
firestorm's Avatar
isnt the labor to change an issue. even if it is better, it costs almost the same to put in the best, so save up if your planing to expand your mod list.
Old Feb 11, 2008 | 02:25 PM
EceSSiveMod's Avatar
is SPEC any good?
Old Feb 11, 2008 | 02:37 PM
rallyracer's Avatar
::smacks you::
Linkage
Well if he would have just said Exedy Stage 3 the first time then I wouldnt have had to search all over the damn place.
"As with all cerametallic clutches, the street driveability may be marginal due to chattering and harsh engagement characteristics."
Nice...not only will your blower sound like a rock tumbler but now your clutch will too.
Old Feb 12, 2008 | 12:03 AM
spec?
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
SSLOW06
Oct 1, 2015 07:21 PM
Tupp
Sep 30, 2015 08:18 PM
