no pedal pressure
Old Mar 18, 2008 | 10:01 AM
ridemlow03's Avatar
no pedal pressure
hey guys well i installed the clutch friday and tried bleeding it sat. my friend and i was bleeding it for like 20 min trying to get the pedal stiffer but it just wouldnt work. i know my clutch slave cylinder is good because when we pulled the tranny off, nothing was leaking from the inside and it only has about 7000 miles on it. im thinking its the clutch master cylinder but the dealership is going to test that today. im thinking that i just didnt bleed it right or something. before we replaced the clutch it had some pressure in the clutch pedal but not much. it was still disengaging but not good. do you guys think that we just didnt bleed it good enough or what??? a guy at my brothers work told me to hook a line from my brake bleeder valve to my clutch bleeder valve. he said to keep the the clutch valve open and bleed the brakes like you would normally do. has anybody ever tried this before???
Old Mar 18, 2008 | 10:12 AM
SSRedSC's Avatar
Ive never tried that and I dont understand how it would do anything. Just keep bleeding your clutch. Id go through a few bottles of fluid before I threw in the towel...
Old Mar 18, 2008 | 12:29 PM
Sufu's Avatar
I thought you were always supposed to replace the bearing/slave cylinder when replacing the clutch?
Old Mar 18, 2008 | 12:32 PM
BlackSS/SC's Avatar
Same thing happened to me when I did my Exedy clutch. I just used the bleeder vavle at first and I'd get a little bit of pressure and then the pedal felt ok for about 10 mintues. Then it would go down, I then tried a vacuum bleeder and it wouldn't do anything for pedal pressure. I eneded up pulling the transmission again and found the slave leaking.
Sucks to say but you gotta pull it again.
Old Mar 18, 2008 | 12:58 PM
SSRedSC's Avatar
Yea you are so that you dont have to rip the ****** apart again when they go...
Old Mar 19, 2008 | 08:59 AM
ridemlow03's Avatar
alright guys well heres the thing, all i did was replace the clutch disc. yeah i know my ******* should have replaced everything while i was in there. i get pressure when i get to the end of the clutch but it still doesnt do nothing. a mechanic was telling me that if you get pressure at the bottom of the pedal then that means the pressure plate is bad. the slave cylinder only has about 7000 miles on it so i dont see why it would be bad.
Old Mar 19, 2008 | 09:14 AM
chris88z24's Avatar
You are. That's why the OP is having problems.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
no_ss
Oct 18, 2015 11:58 PM
Tupp
Sep 29, 2015 11:07 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
