View Poll Results: Which set do you have and what do you think about it?
OTT Stage 2 Rotated Trans Mounts and no complaints at all
46
74.19%
OTT Stage 2 Rotated Trans Mounts but.... (post below)
4.84%
TTR STOP Trans Mounts and no complaints at all
13
20.97%
TTR STOP Trans Mounts but.... (post below)
0%
Voters: 62. You may not vote on this poll
OTT Stage 2 Rotated Trans Mounts or TTR STOP Trans Mounts
Old Feb 13, 2010 | 09:56 PM
MT0911's Avatar
Just curious who has which and what they can say about them.....
Old Feb 13, 2010 | 09:57 PM
ls1fbody's Avatar
Haz l33t wheelz.
OTTP Mounts. They fix the problem. TTR mounts are a copy.
Old Feb 13, 2010 | 09:58 PM
BLAZIN07SS's Avatar
I'm too JDM for you
OTTP. reference my sig as well
Old Feb 13, 2010 | 10:39 PM
MT0911's Avatar
Sounds good, just curious on what people thought.... I'm planning on taking off the Ingalls ETD and Prothane Trans mounts and picking up the TTR Upper Engine Mount and the OTT Stage 2 Rotated Trans mount...
Old Feb 13, 2010 | 10:41 PM
steddy2112's Avatar
Poly top mount won't let the rotated mounts do their advertised job.
All you need is the stage 2 OTTP mounts.
ls1fbody's Avatar
Haz l33t wheelz.
that upper mount will interfere with the rotated mounts, don't bother.
Old Feb 13, 2010 | 10:43 PM
steddy2112's Avatar
Me>j00
Old Feb 13, 2010 | 10:45 PM
ls1fbody's Avatar
Haz l33t wheelz.
you are just faster hoe.
Old Feb 13, 2010 | 10:51 PM
MT0911's Avatar
Good, I thought there might be some issues but wasn't entirely sure. I appreciate the looking out.
Just curious then, which would be a better setup: Ingalls ETD + OTT Stage 2 Rotated Trans Mounts OR TTR Upper Engine Mount +TTR STOP Trans Mounts
Old Feb 13, 2010 | 10:52 PM
steddy2112's Avatar
Just OTTP stage two mounts.
Nothing else needed.
Old Feb 13, 2010 | 11:00 PM
Pyros777's Avatar
OTTP Stage 2 mounts, nothing else. No complaints, loving them.
Upgraded from the GMPP "wheel hop kit" mounts aka T/C mounts. They were a significant upgrade from stock, but still hopped under certain circumstances. OTTP S2 are the best option without a doubt.
Old Feb 14, 2010 | 12:22 AM
qwikredline's Avatar
stage 1 is less money and works for me...cant vote on your poll dont have stage 2, dont drag race....lol
I personally dont care for the idle vibes in stage 2, but either one is better than the TTR "generic" (lol) poly for vibes...
Old Feb 14, 2010 | 01:31 AM
SlowBalt_06's Avatar
but be fooled by others..go ottp stage 1 if your sub 300 hp or stage 2 if over...either way your problems will be solved
Old Feb 14, 2010 | 04:06 AM
Boosted_Cobalt09's Avatar
ottp vs ttr.......ottps are of a higher quality material and weigh maybe half of what the ttr ones weigh.
do what he says!
Last edited by Boosted_Cobalt09; Feb 14, 2010 at 04:06 AM. Reason: Automerged Doublepost
Old Feb 14, 2010 | 06:12 AM
87gn06gto07irl's Avatar
Stage 2 + traction bars = no hop. Now i need a way to fit larger tires to do something about the spin.
Old Feb 14, 2010 | 09:24 AM
Smile
I hate to drill holes in an FE5 arm, but traction bars could have merit for drag racing I am thinking, not that I spend any time drag racing, just two or three visits every couple of years...
So I am wondering why ZZP dont make a provision for traction bars on their chromalloy flca.
Do you think they have tried them? ZZP have to be considered the #1 drag racing shop that participates on this site...
Old Feb 14, 2010 | 06:16 PM
selfinfliction's Avatar
wish they had a way to remove the bushings in the front of the control arm and replace them with some kind of bearing system
Old Feb 24, 2010 | 03:36 AM
kapster's Avatar
Just a question for the ottp stage 1 mount owners, how are the vibes? noticeable at all over stock?
Old Feb 24, 2010 | 07:22 AM
MT0911's Avatar
^^There are almost no vibes at all for the OTT Stage 1 mounts. As for the Stage 2, they have very minimal vibes (but of course they also provide a more solid ride)
Old Feb 24, 2010 | 11:27 AM
SeanEE89's Avatar
What is the biggest difference between the Stage 1 and Stage 2 OTTP Mounts. What is the benefit to paying for the Stage 2 mounts over the Stage 1 set up?
Old Feb 24, 2010 | 11:34 AM
northvibe's Avatar
I have a stage 1 ottp mount...in my living room :/ waiting till spring to install. sorry
Old Feb 24, 2010 | 11:37 AM
MT0911's Avatar
^^ If your sub 300 WHP (which most are unless turboed or TVS) then Stage 1 would be sufficient and a noticeable difference would be felt as far as eliminating wheel hop and have a far more solid drive BUT if you have mid 300's to 400 WHP and are in fact Turboed or TVS than you would see better result (more solid, better protection from Wheel Hop, etc.) with the Stage 2 mounts but with the Stage 2 mounts come a little more vibes when comparing to the Stage 1 mounts of course because the Stage 2 mounts are made to handle high powered applications... Heres a great thread where you can find great information on both the OTT Rotated Trans mounts and TTR STOP Mounts.... https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/comparing-ttr-stop-mounts-ottp-rotated-mounts-205164/....
Check it out and ask whatever questions you have, John from Powell Racing and Aaron from Turbo Tech Racing will provide you with great answers concerning both of the products
Old Feb 24, 2010 | 11:48 AM
northvibe's Avatar
Yeah it was kind of explained that Road track or autox is stage 1 mounts and drag racing is stage 2. I dont plan on making much over 300whp even if I get that high. so stage 1 ottp mounts were perfect.
Old Feb 24, 2010 | 12:13 PM
SeanEE89's Avatar
I am aiming for 300-350whp. I really want to a good car for auto X and time attacks. Nothing serious just looking to have a good time. It will still be my daily most likely but vibration and a stiff ride isn't something I'm concerned with. My old car was a real piece so I'm just happy to have a car that I can have some fun with. With what I'm looking for should I invest in Stage 1 or 2 mounts?
Old Feb 24, 2010 | 01:16 PM
MT0911's Avatar
Here is a proper description taken from OTTPerformance.com:
These new mounts rotate the engine and trans to align the axles. This does two things, it eliminates wheel hop and it helps your axles/trans case survive. Unlike poly mounts these are far less harsh and will have less vibrations. These are made from Billet 6061 aluminum and cnc machined You will have 2 options when ordering.
Stage 1 Use's a Billet rotated front mount with a spacer under the stock rear mount. This is for sub 300whp cars. There will be very little vibration from the mounts.
Stage 2 Use's Billet front and back rotated mounts and the spacer is built into the rear mount. This is for the avid drag racer, these will have slightly more vibration then stock but nothing close to poly. Stage 2 will also help get more power to the ground, due to the mounts limiting engine movement.
Billet mounts are only for 05 and up cars. If you have an 04 please contact us as you will have a core charge on your front mount, a little longer wait period and the pricing is different.
Made by Powell RaceShop for Over The Top Performance.
I would say both options would be great. It's really all up to you; Stage 2 will get more power to the ground (especially since you're planning up to 350 WHP) BUT it will mean increased stiffness and minimal vibes. Personally, I would go with the Stage 2 just because of the power level you're aiming for; but like I said it's entirely up to you. good luck with your build tho
