Perfect Shifting from 1st to 2nd
Old Oct 6, 2009 | 07:02 PM
ssua's Avatar
I'm having a tough time perfect shifting from 1st to 2nd gear!! Anyone can tell when I should shift... Cause everytime I do I feel like it loosing allot of power! plz let me know!!! Thx
Old Oct 6, 2009 | 07:09 PM
northvibe's Avatar
normal shifting, low rpm shifting for mpg, or wot shifting? If you have a SS and are shifting at almost redline...are you nls'ing? try shifting at just under 6k rpm.
Old Oct 6, 2009 | 07:11 PM
D4u2s0t's Avatar
You need to give some more info to get any kind of real answer.
Old Oct 6, 2009 | 07:17 PM
ssua's Avatar
Well it's a '06 SS/Sc.. And I kind of ment like when I'm shifting on High RPM I kind of let it rev for a couple of times and then shift to 2nd gear but I feel like the RPM really goes down and it takes some time for it to get back up. Hope you guys understand what I mean!
Old Oct 6, 2009 | 07:20 PM
~Mike~'s Avatar
That would be you hitting the rev limiter if I'm reading that right which you shouldn't do if you like your car. redline is 6500 rpm, shift at 6
Old Oct 6, 2009 | 07:23 PM
northvibe's Avatar
uh no still dont understand. why would you rev it a couple times then shift into 2nd? you are letting your car slow down and rev'ing up to let it bog? dude floor it, shift normal, shift fast. no need for rev'ing unless you are down shifting and rev matching.
oh mike good point, yeah are you bouncing off the rev limiter? shift at 6 unless you are stage 2 or hpt then you have a rev limit up at/near 7k. so you could shift at 6.5 or closer.
Old Oct 6, 2009 | 07:32 PM
ssua's Avatar
I have a Stage2 so I guess I'll be trying it at 6.5 then!!
Old Oct 6, 2009 | 07:36 PM
~Mike~'s Avatar
don't confuse this person...they're obviously not too familiar with how to drive a manual car. It sounds to me like they're flooring it, hitting the limiter and slow shifting which is causing it to bog. Possibly even a worn clutch that's slipping going into 2nd as well.
OP...until you learn how to drive ur car a little better or get it checked out, I'd calm down on beating up on it or you're going to damage it badly. Just drive normal and shift easy til you get more comfortable with the car because you're obviously new to this.
EDIT: I'm not trying to be a dick, but you'll blow up ur car if ur not careful.
Old Oct 6, 2009 | 07:40 PM
trey ss's Avatar
hahah, my car used to kinda do that, i put a new clutch in it, and now i can birk'm up to 3rd gear!
Old Oct 7, 2009 | 12:10 AM
~Mike~'s Avatar
Ur gonna end up blowin ur car up too lol
Old Oct 7, 2009 | 10:28 PM
trey ss's Avatar
how will that blow up my car? im shifting at the right rpms and it just does it, is that bad? not to sound like a *******
Old Oct 8, 2009 | 12:12 AM
northvibe's Avatar
not sure how chirping the tires during a shift will blow car up...maybe snap a axel or a motor mount.
Old Oct 8, 2009 | 02:04 AM
06SS ALL DAY's Avatar
wow this guy is a tool. im not even trying to be mean... im stage 2 maybe ill try to shift at redline... come on guys... that doesnt seem a litttlle odd
Old Oct 8, 2009 | 05:56 AM
mattcossel29's Avatar
Got some advice for ya when you are shifting that hard...
F35 FTL...
I know, I have replaced mine just after a new clutch..
Old Oct 8, 2009 | 07:31 AM
trey ss's Avatar
sorry im kinda a noob, to the cobalts and cars in genneral, what is f35 ftl? again not trying to be a tard
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Fearedbynone
Apr 14, 2016 03:25 AM
Oct 20, 2015 09:56 PM
Oct 13, 2015 09:32 PM
2009blackSS
Sep 30, 2015 05:57 PM
