Pics of my Exedy clutch after 10 000
Nope, I wasn't going the accusation route. I was just involved in thought there and listing the possibilities. I don't make judgements like that from far away.
Well, I hope the new clutch works out for you. As for the old flywheel being sold, it has to be sold with the pressure plate as well or it'll be useless. The Exedy setup cannot be used interchangably with other clutch components due
to it's design and how they work together. Just figured I'd give you a heads up.
Well I finally got work from Exedy. They said the pressure plate and flywheel are both fine. The maximum runout is .55mm on the pressure plate and mine is .23mm so it's fine. Anyone want to buy the flywheel and pressure plate? Save ya some money and then you just have to get a disc.
