Poly Trans Mount Idea.
Old Jan 9, 2007 | 01:07 PM
tricky1's Avatar
This applies to the LS/LT cobalts. The Intense inserts do not fit in the stock 2.2 mounts. However the Cavaliers appear to use almost identical mounts to the Cobalt. This is mainly because the 95-99 Cav's used a Isuzu Transmission and the 00-05 Used the Getrag F23, the exact same as the Cobalts.
This brings me to my point, It is possible that the Cavalier Inserts will work for the 2.2 guys. If you look at this page with the inserts on TTR the front mount looks very similar to the Cobalts, in fact the Cobalt front mount says "CAV.2" on it.
http://www.turbotechracing.com/produ...idcategory=709
Thoughts?
Old Jan 9, 2007 | 02:13 PM
TurboTechRacing's Avatar
If someone will measure the width of the casting and the diameter of the hole. We will know if GM used the same size, if not we WILL make these if we see an interest.
Old Jan 9, 2007 | 02:19 PM
halfj99's Avatar
i can almost promis these will be the same
Old Jan 9, 2007 | 02:22 PM
This is what we are thinking, and if this is the case, we have the perfect item for every 5 speed 2.2 owner on this site
Prothane have holes in them, and they still have A LOT of play. Ours, Turbo Tech Racing, are 100% solid, and available in red, black, and blue.
If someone can get the dimensions mentoned above we can verfy the fitment.
Old Jan 9, 2007 | 02:29 PM
halfj99's Avatar
the parts in red are the mesurments needed?
Old Jan 9, 2007 | 02:40 PM
cawpin's Avatar
If it isn't here by the time I get home tonight I'll measure my stock mount and post back here.
Actually we need 4 measurements to start:
1. the large red circle, the outside of the bushing diameter
2. the inside diameter of the bushing where the sleeve pushes into
3. the inside diameter of the bushing
4. the width of the casting that the bushing goes into
Old Jan 9, 2007 | 02:45 PM
tricky1's Avatar
https://www.cobaltss.net/forums/show...t=39884&page=2 Post #22 has the approx diameter as measured by me with a tape measure a while back.
Old Jan 9, 2007 | 02:48 PM
Here is the basic starting measurements...
Old Jan 9, 2007 | 02:51 PM
Dim 1 on the cavalier bushings is about 3.5" in diameter...
Old Jan 9, 2007 | 02:55 PM
halfj99's Avatar
that would be awesome...id do it but my jack is at my parents which is a 30min trip. and its 25 degrees and windy lol
Old Jan 9, 2007 | 03:03 PM
tricky1's Avatar
1. Bushing OD: 4"
2. ID of Mount: ~3.75"
3. ID of Bushing: ~3.75"
4. Width of Casting: 2"
Old Jan 9, 2007 | 03:04 PM
tricky1's Avatar
Those measurements all came from the bushing. I had an extra bushing that I measured.
Old Jan 9, 2007 | 03:23 PM
Originally Posted by tricky1
1. Bushing OD: 4"
The bushing OD is 4" and the casting ID is 3.75" how does this work? lol
Also #3 you say 3.75" ID of bushing... this should be .75-1.5" we are guessing...
Old Jan 9, 2007 | 03:38 PM
tricky1's Avatar
The Casting ID would be 4" with a lip inside going down to ~3.75"
Old Jan 9, 2007 | 03:39 PM
tricky1's Avatar
OK I figured out what you meant...the ID of the bushing is ~.75"
Old Jan 9, 2007 | 03:41 PM
The outside of the bushing (OD)
The inside hole diameter of the aluminum sleeve (ID)
The width of the rubber bushing
The length of the aluminum sleeve.
What trans is that from 2.0 or 2.2L
Old Jan 9, 2007 | 03:43 PM
You have a side view of the bushing?
Old Jan 9, 2007 | 03:47 PM
tricky1's Avatar
2.2L Getrag F23
Both pics:
Old Jan 9, 2007 | 03:52 PM
tricky1's Avatar
OK for DIM 4 it's 2.75"
DIM1: 4"
DIM2: .75"
DIM3: Min 3.75" Max 4"
DIM4: 2.75"
Old Jan 9, 2007 | 04:00 PM
Anyone have a set you could send us, front and rear (brakets and bushings complete), you will get a new set of solid bushings for free. If interested email me @ Aaron@TurboTechRacing.com
Old Jan 9, 2007 | 04:05 PM
tricky1's Avatar
I've sent mine to CobaltPerformanceParts...maybe Scott has the dimensions you need.
Old Jan 9, 2007 | 04:09 PM
Once we get a set in here, 2 weeks MAX and we will have them shipping.
Old Jan 9, 2007 | 04:15 PM
tricky1's Avatar
If I could go without mine again I would.
Jan 12, 2016 12:01 AM
Oct 20, 2015 09:56 PM
OrangeCoba
Oct 1, 2015 10:00 PM
Tupp
Sep 30, 2015 08:18 PM
