Possible transmission issue, help wanted.
Old Jul 27, 2014 | 04:10 PM
smitzk01's Avatar
Hey all, I drive a 06 SS/SC. As the title states I think I am at the forefront of transmission issues/failure.
First I want to list what I have. I am running a stage 3 ky clutch, revised shifter bracket, and Ottp rotated mounts.
I have noticed that my car has been making a slop noise(closest I can think of is a bad pulley bearing) when in neutral. At first I thought it was maybe the supercharger coupler wearing out but then I noticed The noise goes away when the clutch is depressed. Also no noise when in gear. Very rarely I have a hard time putting the car in reverse.
I work at a Mazda dealership so I was asking my senior tech about my problem. He said he believes it isn't the throw out bearing because the noise goes away when the clutch is depressed or in gear. However, nobody at my shop is really specialized in transmissions.
Friday I changed the transmission fluid and put in fresh redline mt-90. I knew it probably wouldn't cure the noise which it didn't but I wanted to see the fluid. The fluid was dark, didn't smell burnt, and no signs of heavy metal deposits. The fluid seemed pretty normal after two years of service. I also checked alldata for technical service bulletins. The closest I came to was a noise with the added complaint of hard to put in reverse and fifth gear. The tsb said to replace the main shaft and bearings.
I wanted to start a thread and ask if anyone else with mods similar to mine or a lot of experience with the transmissions in these cars for advice or a direction to look. Maybe somebody has had similar problems and has found the fix.
Thanks for reading.
Old Jul 27, 2014 | 04:21 PM
turbocharged717's Avatar
probably just clutch chatter.
Old Jul 27, 2014 | 09:59 PM
smitzk01's Avatar
I have heard of that but I never thought it was this noisy. Does chatter only happen in neutral idling?
Old Jul 28, 2014 | 04:55 PM
yes from my experience it's only in neutral with pedal out. i had an after market clutch in a previous car that did the same thing an act six puck. it was like that for a few years till i traded it in.
Old Jul 28, 2014 | 05:09 PM
user 72239's Avatar
Mine does this when its been sitting for awhile or its very cold out. I did a lot of research and everything says its the Input shaft bearing going bad if its whirring in neutral with the clutch NOT Depressed
If the clutch is Depressed and its whirring, then its the Throw out bearing.
Old Jul 28, 2014 | 05:13 PM
i didn't know how much weight the input shaft possibility held. i heard that once before but never had it fail/break in 4 years, so i chalked it up to chatter.
Old Jul 28, 2014 | 05:15 PM
user 72239's Avatar
yeah mine has been doing it for a long time. it never gets louder.
Old Jul 28, 2014 | 05:18 PM
mine was always the same as far as loudness too, i thought something was going to break but it never did.
Old Jul 28, 2014 | 05:45 PM
smitzk01's Avatar
Thanks for the replies. I am not sure exactly what it is, but I'm just going to run it until it gets louder or fails if it ever does.
I would love to think it is normal but something tells me it isn't.
Still up to hear from anyone who has experienced this and solved the issue.
RaginChopsuey
Oct 27, 2015 01:27 PM
Trav3480
Oct 1, 2015 08:17 PM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
