? for ppl w/ SPEC 2+ & 3+
im am working on building a 340whp LSJ. I want to hear from ppl with the SPEC 2+ & 3+ clutches and how they are holding up. I also want to know how much torque or horsepower you are pushing with whatever clutch you have. thanks
I will leave this for others however I will say you are on the right track. Get the "+" series only, the ones that have issues seem to have the NON "+" series, where as the ones that like the SPEC setup have the "+" series.
Which exact part number/model did you get?
Last edited by TurboTechRacing; Dec 9, 2009 at 07:56 PM. Reason: Automerged Doublepost
I have installed a few 2+ clutches in some 270ish horse LSJs and one in a 300+hp LNF. None of them ever came back or bitched to me about it.
The Exedy Hyper Single is pretty badass as well, I did the Exedy test fitting for the LNF, it worked flawlessly and held up to a solidly 300+hp car with zero issues, I have nothing but good things to say about it, the Spec has a closer to stock pedal feel and is cheaper, but doesnt come with a flywheel or the higher quality pressure plate cover. You upgrade those items on the SPEC and the price is about the same as the Hyper.
I've been running the 2+ for about a year now. I DD it everyday. No problems whatsoever. I can def recommend it.
I have teh TVS w/ 2.9, Full 3" catless exhaust, meth, all other supporting ****.
11.6ish A/F 23* timing. I'm prob close to the 340hp mark i guess...
Hope that helps -Dan
i bought the stage 2+ from TTR. what i dont understand is that SPEC rates this clutch for 440 torque! i havent heard of anybody having problems w/ the stage 2+ but whats everybody worried about...or does SPEC overate their clutches?
