Proper clutch bleed question
Old Dec 26, 2017 | 11:29 AM
cw383's Avatar
I've already did a clutch change and an engine swap, both times I bled the clutch to what I would call my satisfaction. Here is 2 questions for someone in the know.
1: Both times I did mine I bled it at the distribution block on the trans, The first time It was all manual pumping, second time I used a power bleeder. Now in looking thru the forums I see bleeding being done thru the master cyl using a stopper and power bleeder to pull vacuum. Was I doing it wrong? Does it matter?
2: Can you over bleed them? I seem to recall reading somewhere if you bleed it too much you can use up some of the self adjusting depth on the TOB. Sounds silly, but I do get clutch engagement a few inches off the floor and I wonder if that may be why?
I also notice I sometimes get locked out of second when I try to speed shift. I wonder if any of this may have something to do with that?
Old Dec 26, 2017 | 11:50 AM
royce777's Avatar
Every time I've done it I manually bleed it with two people. Just to be safe I drive it a few miles and rebleed.
Old Dec 26, 2017 | 12:10 PM
cw383's Avatar
Did you bleed it from the brake reservoir or the bleeder on the trans?
Old Dec 26, 2017 | 12:49 PM
royce777's Avatar
Old Dec 26, 2017 | 12:54 PM
T-Man's Avatar
In order to ensure zero air in the system, best bet is to bleed all four corners and then hit the trans bleeder. It's a shared reservoir for both the brakes and the clutch MC/slave.
Old Dec 26, 2017 | 09:47 PM
ItalianJoe1's Avatar
I always vacuum bleed though the reservoir as per the factory instructions. Works great, delivers a nice pedal after 3-4 cycles, no mess, can be done solo.
Old Dec 28, 2017 | 08:37 AM
jdbaugh1's Avatar
Bleed mine with two people just pumping and then releasing at the nipple on the fitting that goes into the transmission. Pump, pump, pump and then release until air quit coming out. Only did the procedure once and haven't had a spongy clutch feel or any other issues.
Old Dec 28, 2017 | 09:34 PM
2slo3oh's Avatar
I have always used a pump bleeder at the trans.
Old Dec 28, 2017 | 10:39 PM
This. Easy, quick, works within a few cycles, and doesn't get fluid everywhere.
slacker
Mar 8, 2026 02:54 PM
bdwarr6
How to Guide
Aug 27, 2011 06:22 PM
Johnboy12358
May 31, 2009 10:26 PM
truray4
Nov 9, 2006 12:49 PM
StreetDreamz
How to Guide
Jul 18, 2006 11:26 PM
