Drivetrain: The impossible to bleed clutch...
Old Jul 18, 2006 | 11:26 PM
StreetDreamz's Avatar
Go get a one-man bleeder kit from your local auto store. Put one end of the hose on your bleeder valve (Make sure the valve is only finger tight, but the hose is on good and tight) and the other end on the top of the bottle. Make sure the brake/clutch fluid resovoir is full the whole time you do this, if it goes down a little at all fill it back up to the brim. There is a slight hole just below full that I believe is the baffle that directs fluid into the clutch line. Fill a part of the bottle with fluid just enough to get the hose inside of it under the fluid level then close the bottle and put it above the bleeder valve somewhere so the air bubbles have an easy upward path. Now go pump the pedal a few times and release it. Go under the hood and loosen the valve a little until the fluid starts to flow, you will see lots of bubbles the first time. Let it flow until all the big bubbles really stop coming or the bottle gets full. Then close the valve. Make sure the car's resovoir doesn't get empty. Dump some of the fluid out of the bottle and close it back up, be sure to keep the hose under the fluid level. Pump the pedal a few more times and release it. Go back under the hood and turn the valve until all the little bubbles stop coming, then close it again. If the bottle is full, dump it. Watch the car's resovoir. Pump the pedal a few more times and release it. Go under the hood, loosen the bleeder, let it flow until it's just plain liquid going through, no bubbles, then close it. Make sure the resovoir is good and full then put the cap back on. Pull the bleeder kit out and start the car, pump the pedal a few times, should be decently stiff but not loose. It will engage like 2" from rest now and there will be no need to come anywhere near the floor to disengage the pressure plate.
Enjoy.
codyss
Apr 20, 2019 11:06 PM
Solaris99
28
Mar 15, 2017 01:22 PM
Tupp
Sep 29, 2015 11:07 PM
djt81185
Jun 12, 2006 10:16 AM
