Quick need a tech specialist
Hi, I have a flywheel that someone stripped one of the bolt holes and I need to put a helicoil, problem is stock bolts are in car right now, and I want to get the holes drilled and retapped asap before I take apart car. I need to know the bolt size for the hole. Basically Threads per inch. If anyone can do this for me it would be greatly appreciated. Thanks
I'm doing 4, and I know everything about unbalanced. I talked to Fidanza personally and he said is when they repair one they throw on in the other side, but I'm one upping and doing 4. I do drill and taps as a job as a tech on much worse then a piece of aluminum, like 6000# 1000* steam, while it's leaking, so I'm not worried about any of this. He also said that their high performance custom ones all have helicoils in them for strength.
I just need the thread count. Unfortunately finding a bolt like that at a store can cause a problem if by chance I try a metric in a standard hole, it could potentially strip a thread off, even though worse case is I may end up doing it anyway. But, I'm just wondering if any techs out there would know. Thank you.
agentirons
Oct 16, 2015 02:11 AM
