Quick need a tech specialist
Old Jun 19, 2007 | 09:29 PM
Julex's Avatar
Hi, I have a flywheel that someone stripped one of the bolt holes and I need to put a helicoil, problem is stock bolts are in car right now, and I want to get the holes drilled and retapped asap before I take apart car. I need to know the bolt size for the hole. Basically Threads per inch. If anyone can do this for me it would be greatly appreciated. Thanks
Old Jun 19, 2007 | 10:25 PM
2K5SS/SC?'s Avatar
Take the flywheel to the hardware store and thread a bolt in. One helicoil installed on the flywheel could throw off its balance and cause problems down the road. Be careful.
Old Jun 19, 2007 | 10:34 PM
jeremie's Avatar
i would get a new flywheel, since its balanced. the slighest imbalance will multiply as rpms build.
Old Jun 19, 2007 | 10:48 PM
CobaltPerformanceParts's Avatar
I would also recommend just getting a new flywheel.
Old Jun 20, 2007 | 04:53 PM
Julex's Avatar
I'm doing 4, and I know everything about unbalanced. I talked to Fidanza personally and he said is when they repair one they throw on in the other side, but I'm one upping and doing 4. I do drill and taps as a job as a tech on much worse then a piece of aluminum, like 6000# 1000* steam, while it's leaking, so I'm not worried about any of this. He also said that their high performance custom ones all have helicoils in them for strength.
I just need the thread count. Unfortunately finding a bolt like that at a store can cause a problem if by chance I try a metric in a standard hole, it could potentially strip a thread off, even though worse case is I may end up doing it anyway. But, I'm just wondering if any techs out there would know. Thank you.
dennis69
Oct 20, 2015 07:39 AM
agentirons
Oct 16, 2015 02:11 AM
patooyee
Oct 15, 2015 05:11 PM
justinchinn
Oct 2, 2015 12:18 PM
ColonelMustard
North Pacific
Sep 29, 2015 03:02 PM
