Replacing CV Axles
Old Oct 16, 2008 | 10:50 PM
06SS/SC STAGE2's Avatar
Replacing CV Axles
Is there anything I need to know when replacing my cv axles. Im installing new ones this weekend. Looks as if they just slide right in place. But I am a little curious about what looks like a "C" clip on the input spline.
Let me know guys, so I dont screw things up. Im hoping this will cure my vibration I have been having since my sportline install. Its the only thing left that could be causing it.
Old Oct 16, 2008 | 11:52 PM
Halfcent's Avatar
I'm old school
You need to unbolt the strut in order to obtain the clearance to remove it. Once that's done, use a large pry bar to simply pop them out of the sockets of the trans.
Old Oct 17, 2008 | 06:32 AM
Thanks Halfcent. Could you also tell me what is the size of the alen wrench to open the fill and drain plugs on the tranny?
Old Oct 17, 2008 | 08:58 AM
Cougarguy's Avatar
I have found if you lift both front wheels to an even level it makes them come out easier, also MAKE SURE THE C-CLIP COMES OUT! you have to make sure its still on the axle, if not fish it out. it probably will, but i recently had to do a trans from a c-clip from 6 months ago so 1/20 it happens lol.
Old Oct 17, 2008 | 11:27 AM
Halfcent's Avatar
I'm old school
Sorry, I don't know off the top of my head. But I assume if you have a simple metric set of allen keys, one of them will work.
Old Oct 17, 2008 | 07:57 PM
Ok thanks guys. Just looked at the How To change your tranny fluid and it says 8mm. Im just hoping this axle change will cure my vibration. I love the car lowered and dont want to raise it back up with the stock springs, but Im not gonna distroy a new set of axles if the vibration dosnt go away. I will then rais it back up.
biniecki
Oct 25, 2015 02:23 PM
agentirons
Oct 16, 2015 02:11 AM
justinchinn
Oct 2, 2015 12:18 PM
DANRICKARD
Oct 1, 2015 12:08 AM
importkiller
Sep 30, 2015 07:18 PM
