Short shifter install? (b&m)
Old Apr 22, 2006 | 11:16 AM
myfriendscobalt's Avatar
for those of you who have a b&m shifter or any short shifter for that matter,how easy was it to install?Is there a noticably difference when you shift compared to stock?
Old Apr 22, 2006 | 11:24 AM
PlaysWitCars's Avatar
Former Cobalt Owner
it was a very simple install but the stock shift knob was a pain in the ass to get off. its a quicker shift than stock (which it should be..hence short shifter)
Old Apr 22, 2006 | 05:08 PM
BooSSted's Avatar
How did you get the stock knob off? I just ordered my B&M today
Old Apr 22, 2006 | 09:56 PM
2K5SS/SC?'s Avatar
I got the stock knob off by taking the whole assembly out of the car. Four main bolts holding it down, and the two snap connector for the shifter. Pullout the assembly and take a long flathead screwdriver and put it under the knob where the reverse lockout slides into. I hit the bottom of the screwdriver on the curb in front of my house while holding the rest of the assembly to prevent damage. After two blows the knob flung like 10 feet into the air, and it was off! The only other tricky part is being carful removing the plastic piece you'll need from the orginal shifter assembly. Good Luck!
Old Apr 23, 2006 | 12:56 AM
BooSSted's Avatar
^^^^There has got to be a better way then that. I can't see myself beating something off the curb to get it off.
Old Apr 23, 2006 | 02:52 AM
StreetDreamz's Avatar
There is. I cut my stock knob off the top of it's lever with a cut-off whell and then pulled off all the pieces. The whole process was about 20 minutes start to finish.
Old Apr 23, 2006 | 06:40 PM
2K5SS/SC?'s Avatar
You beat the end of the screwdriver. It didn't hurt the end of the knob at all. I could put the old shifter back in the car still perfectly if I'd like to. Nothing broke. The stock knob is pressed onto the shifter. It takes force to get it off, and that was my method. Use could use a hammer/rubber mallet if you'd like instead.
Old Apr 23, 2006 | 07:51 PM
Why would you ever want to put the stock shifter back on? Even if you were trding the car in it only works in a few select cars. And to resell it would be like $50. Makes no sense to me really.
biniecki
Oct 25, 2015 02:23 PM
dennis69
Oct 20, 2015 07:39 AM
justinchinn
Oct 2, 2015 12:18 PM
Delta coupe
Sep 30, 2015 08:11 AM
Bohb
Sep 27, 2015 09:11 PM
