Should I get the Exedy hypersingle
Im no expert on clutches but have been talking about this for the past few weeks, and the Hypersingle isnt a 6 puck clutch. Its the best clutch available for the LNF. Pedal feel should be similair to stock. Dont believe you will ever need to replace it or max it out. Its expensive as ****, I got quoted at 1750 for clutch installed at a local shop. Otherwise the Spec stage 1 I believe is a good choice too as its not a 6 puck clutch and will hold more tq then the stock clutch
It is def a 6 puck clutch
LOLWUT on a stock like pedal...nothing has a lighter clutch than an LNF.
apparently your right, i heard it wasnt and 6 puck clutches suck cause they break on this car so its best to steer away from six puck and I heard the hypersingle was the best clutch. Now i hear its 6 puck. So WTF. i dont wanna drop 1100 on the hyper single when I can get a Spec clutch for cheaper
Hypersingle is a kit that comes with a 6 lb cromoly steel flywheel, none of that aluminum crap
Last edited by steddy2112; Jun 20, 2010 at 07:02 PM. Reason: Automerged Doublepost
Yes, I've been running one for many thousand miles now with the lightweight flywheel.
I would keep the stock FW if I were doing it over, kills easier but does rev up quicker and I had to put the ZZP adj clutch rod in to get the pedal off the floor where it grabs.
Stock FW and the SPEC requires the dowel holes be drilled out to 12MM to fit the pressure plate but some just left the dowels out without issues counting on the bolts alone for alignment.
LW flywheel bolts right up fine. No clutch slippage at 380 wtq.
How 'bout the ZZP Stage 4+? That's what I wish I would have done.
thmotorsports
52
Sep 4, 2007 10:27 PM
