still rough to get in gear after wot
Old 05-17-2011, 11:07 AM
seeyaass's Avatar
As the title states, during wot its hard to shift into the next gear I bled the clutch multiple timed, any input? Its a clutchmadterd sstage 3.. any input?
Old 05-17-2011, 11:09 AM
BYT*SS*TURBO's Avatar
Aren't you coming on Thursday??
Old 05-17-2011, 11:27 AM
seeyaass's Avatar
Made the appt for wednesday and it was for a tune e can vaccuum bleed while im there?
Old 05-17-2011, 11:35 AM
yup
Old 05-17-2011, 11:56 AM
seeyaass's Avatar
Ok see ya sometime tomorrow then
Old 05-17-2011, 12:34 PM
Cool! Yea, def tomorrow! You were right, just checked the calendar
Old 05-17-2011, 12:42 PM
Baron7700's Avatar
gasper dont do it, he magically blows motors, especially if he is bleeding your clutch, or puttin air in your tires rofl
serious note. How hard we talking here? Might just be the shift cable, I know when im at a higher rpm or load my stocker is harder / more resistant to shift, i was under the assumption from reading that its just the crappy linkage. you don't have a sts do you?
Old 05-17-2011, 12:47 PM
He does, he has the Hurst IIRC. Im going to try adjusting that as well, it was wacky when I got the car so I adjusted it a bit. It may need some more
Old 05-17-2011, 12:58 PM
Baron7700's Avatar
i would guess its just that? Don't adjust it to much, otherwise youll lose compression in a cylinder.
Old 05-17-2011, 12:59 PM
That only happens when the BOV is pissing oil.. But don't worry about that lol
Old 05-17-2011, 01:18 PM
Baron7700's Avatar
ya the oil creates to much pressure in the shifter cuz it heats up. So it gets dumped out the bov for two reasons. One to relieve the stress on the shifter so you can bang thro the gears better, and two, since the motor is running hotter it dumps the oil out on top to help cool it off. Just like how we sweat. Its a pretty neat design by GM actually, surprised more companies dont do it. OP, once nick gets the amount squirted out corrected, youll be golden
Old 05-17-2011, 01:49 PM
Then just another millisecond on the NOS timer and you'll be running 9's
Old 05-17-2011, 02:32 PM
seeyaass's Avatar
Lol guys, well I have adjusted it so there is no extra "space" in 5th gear and it worked fine for me.. and if it was the cable, why does it shift fine during low rpms and normal driving ya know? Nick when I got it back from ya I had the 5th gear space so essentially I thought that's what it was, but I changed the clip placement to where there is no space lol
Old 05-27-2011, 03:24 PM
Baron7700's Avatar
I have no idea and thats a good question
Old 05-27-2011, 03:41 PM
Chevycobaltss3's Avatar
Only time that happened to me was when i had my Clutchmasters. 6 puck double sprung. Throw springs on one side shot out..
Old 05-28-2011, 10:23 PM
Baron7700's Avatar
well mine does that, its harder to put it in gear or I should say more resistent at higher loads and or rpms.
Old 05-29-2011, 10:36 AM
Hmmmmmmm..
Sl0wbaltSS
11-21-2018 11:11 PM
bigdeertz
11-17-2016 09:41 AM
biniecki
10-25-2015 02:23 PM
10-13-2015 09:32 PM
Trav3480
09-28-2015 02:46 PM
Quick Reply: still rough to get in gear after wot
