suggestions?
Old Nov 30, 2007 | 09:36 PM
matt_SS_205's Avatar
suggestions?
alright guys, i just got some new rubber about 2 months ago, they grip like no other, but... they have caused my clutch to start slipping on the 1st-2nd shift, used to it would just spin on the old tires, but now it's makin the clutch slip really bad. so i'm asking the experts, i want a clutch that will not slip, but won't make my left leg 3846658 times bigger than my right lol, any suggestions?? i'm kinda liking the Spec 3+ or an Exedy, i want a light weight flywheel as well, thanks in advance
Last edited by matt_SS_205; Nov 30, 2007 at 09:36 PM. Reason: Automerged Doublepost
Old Dec 1, 2007 | 08:44 PM
come on guys i need some help here! i noticed on Turbo Techs website the SPEC Clutches have a lightweight option, what is that?
Old Dec 1, 2007 | 09:40 PM
DTM2188's Avatar
Go with the Exedy. I've never heard one bad thing about the Exedy cluthces. I plan on running one on my Evo when the time comes.
Old Dec 1, 2007 | 10:05 PM
only thing with Exedy can you get a lightweight flywheel with it?
Old Dec 1, 2007 | 10:11 PM
D4u2s0t's Avatar
are you positive it's the clutch slipping, and not the tires actually spinning instead of hopping? happened when i changed tires a few times, i kept thinking my clutch went out till i realized the new tires don't hop, they just spin. happened anywhere up to about 70.
Old Dec 1, 2007 | 10:15 PM
no it's not the tires spinning, when i shift hard into second the RPM's go up and then all the sudden it goes in gear
Old Dec 1, 2007 | 10:16 PM
SSweet06's Avatar
I had the SPEC Stage 3+ and SPEC flywheel and I was very happy with it. The pedal feel was as easy as stock. I would recommend it. But I hear great things about the Exedy. NOBODY!! had them in stock for months when I wanted one so that why I ended up getting the SPEC. Either way you can't go wrong IMO. The Exedy comes with a lighter flywheel.
Old Dec 1, 2007 | 10:22 PM
ok THANK YOU for answering that question about the lighter flywheel, i thought i had heard that it did, but i couldn't find any info to back it up
Old Dec 1, 2007 | 10:47 PM
SSweet06's Avatar
No problem, anything I can do to help! The Exedy's come with a steel flywheel instead of aluminum so i'm pretty sure they are a little heavier than and an aluminum one but lighter than factory.
Old Dec 1, 2007 | 10:50 PM
ok that's what threw me off is it said it was steel and i just figured it was prolly same as stock, oh and should i order a new slave cylider and throw out bearing? if so where do i go to find some of them besides the stealership?
Old Dec 1, 2007 | 10:59 PM
SSweet06's Avatar
I'm not positive. I just reused the factory ones. Intense Racing installed my clutch and flywheel. They didn't ask me if I had new ones or suggest that I buy new ones so I would say it doesn't matter.
Old Dec 1, 2007 | 11:02 PM
ok i've heard some say you need them others say you don't, now i just gotta get enough money for the clutch and imma go ahead and upgrade the axles, and then find someone to install eveything
Old Dec 1, 2007 | 11:06 PM
TurboTechRacing's Avatar
We have an AWESOME deal on Exedy! PM us, only 1 left at this price!
If you want a SPEC stage 3+ let us know we can hook you up with that also.
Old Dec 1, 2007 | 11:07 PM
SSweet06's Avatar
Sounds like a good plan. Better save up quite a bit. Intense charged $525 plus oil to install. I think it came to $585 or so. So it was like $1700 for clutch, flywheel, and install.
*EDIT* Aaron from TTR gave me a great deal on my Spec clutch. I would recommend from getting either clutch from them
Old Dec 1, 2007 | 11:12 PM
ok i know NOTHING about clutches i'm learning as i go here, do you have to put oil in them on the install or are you refering to engine oil, and yea i am planning on gettin the clutch from TTR when i do it
Old Dec 1, 2007 | 11:14 PM
SSweet06's Avatar
I don't know much either but as far as I know its the transmission fluid
Old Dec 1, 2007 | 11:16 PM
No you dont need to change the tranny fluid when you do a clutch install. You dont remove any parts that would drain the oil from the tranny. You can, as general Matn. but it is not needed.
Old Dec 1, 2007 | 11:19 PM
ok thanks i didn't think you had to change any type of fluids, and TTR it may be awhile but i will be contacting you about purchasing one of the mentioned clutches
Old Dec 1, 2007 | 11:20 PM
SSweet06's Avatar
Didn't think you had to but for some reason Intense did
Old Dec 1, 2007 | 11:21 PM
Sounds great...
turbochargedss2012
Sep 20, 2023 12:17 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
TedSS
26
Oct 10, 2015 04:30 PM
yellow dragon
Sep 28, 2015 09:49 PM
budah93
Sep 23, 2015 02:26 PM
