Thumping Noise
Old Apr 5, 2010 | 09:07 AM
Yamaha74's Avatar
Thumping Noise
I have a 2007 Cobalt LS and there is a thumping/kocking noise in the front end. This car has 77K miles on it. It has been doing it for a long time now but in the last 3-4 weeks it has really gotten worse. Basically it happens when I am going over bumps at any speed. If I am on smooth road there is no noise. Yesterday I rotated my tires and why I had the tires off I checked a few things and one thing that I noticed was when I grab on to the axles on both sides of the car and pull them in and out they move about 3/8" and make about that same knocking noise. Is this normal and if not does this mean that my wheel bearings are bad or could it be something else?
Old Apr 5, 2010 | 09:30 AM
Eurasianman's Avatar
I think you might need a new hub. I just had the rear passenger side hub replaced and noticed you can't access the wheel bearing, the whole thing had to be replaced. To keep my car with GM warranty, I had to get a GM hub (~$270) and have them install it ($190 for labor). But your car might be out of warranty, so you could probably fix this yourself. However, I only knew the hub was messed up because it would make an odd 'whopping' noise when driving, but the ride itself was still smooth. Hope this helps.
biniecki
Oct 25, 2015 02:23 PM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
jimbofug007
Oct 2, 2015 12:06 PM
DANRICKARD
Oct 1, 2015 12:08 AM
Tupp
Sep 30, 2015 08:18 PM
