Tranny Tools
Old May 10, 2008 | 05:33 AM
USMCFieldMP's Avatar
Rattlesnake Race Shop
Anything works... well, except for the J tool 87 numbers that gm has in the service manual.
Old May 10, 2008 | 05:47 AM
silverfae7's Avatar
Well, looks like I won't be of any help to you. All I could find are the 87 numbers. Sorry bout that. They all show to be good numbers though.
Old May 10, 2008 | 06:28 AM
Where are they supposed to be ordered from? My dealership called the/a place and they said they don't have those numbers on file. I would assume that there is only one place for them to be ordered from.
WTF... this is pissin me off. I don't see how they can't be able to order the tools. I might have to go postal on this one.
Old May 11, 2008 | 06:09 AM
silverfae7's Avatar
I've got good news and bad news. I found all the tool numbers you will need but... you will have to go through 179 pages of special tools to find the ones you are looking for. Hopefully you know which ones you need. https://gmspecialservicetools.spx.com/SearchTools.aspx On the right side do a vehicle search. It will list all the tools plus some universal ones. Good luck.
Old May 11, 2008 | 11:23 PM
Maven's Avatar
Okay, sorry I couldnt get back to you. Ive got two sets of F23 tools but it appears as though most of the F35 tools have either walked away or in other peoples boxes at this time. I can tell you that the reason you cant find the tools you need is because the majority of the special tools for the F35 arent normal GM "J" or "DT" tools, this is because they are SAAB tools , so they are numbered differently. the numbers below are accurate.
78-41-067
Sleeve Inner Driver
83-90-114
Sleeve
83-90-312
Drift, Bearing Race Input Shaft
87-90-636
Pinion Fixture
87-90-800
Drift, Differential Seal
87-90-867
Input Shaft Bearing Ring
87-91-121
Input Shaft Bearing Puller Ring
87-91-188
Screw Press Support
87-91-204
Output Shaft Bearing Race Sleeve
87-91-261
Output Shaft Remover
87-91-287
Puller
87-91-295
Puller Arms, 300 mm
87-91-303
Puller Arms, 150 mm
87-91-311
Sleeve, Bearing Driver Shaft
87-91-410
Output Shaft Protector
87-91-428
Driver
87-91-642
Basic Puller
87-91-972
Assembly Ring
87-92-053
Companion Flange
87-92-061
Millimeter Disc
87-92-095
Weight (10 Kilograms)
87-92-103
Output Shaft Assembly Tool
87-92-129
Lifting Eye
87-92-137
Milled Bearing Race
87-92-152
87-92-178
Output Shaft Puller Ring
87-92-202
87-92-210
Support, Differential Bearing
87-92-236
Support
J 7754-C
Torque Wrench Beam Type
J 8001
Dial Indicator Set
J 8107-2
Side Bearing Puller Pilot
J 22875
Differential Bearing Installer
J 22888-20A
Universal Two Jaw Puller
J 22919
Differential Side Bearing Installer
J 24319-B
Steering Linkage and Tie Rod Puller
J 25031-A
Three Jaw Puller
J 35616
GM Terminal Test Kit
J 39511
Countershaft Bearing Installer
J 43483
Impact Driver
J 44362
Input Shaft Support
J 44394
Seal Protector
J 44809
Output Shaft Seal Installer
As you can see, very few of the tools needed to service the F35 are regualr KentMoore "J" tools, and those few that are, several are fairly generic and they are readily available from other sources
Wish I could have been of more help, but I am really an F23 guy, hope the list gets you closer
Old May 14, 2008 | 10:09 AM
Thanks... those seem to be the numbers that are in the Service Manual... the ones that the dealer has been trying.
They are calling a SAAB Dealer today to see if they have them. Hopefully, the numbers are the same, as you say they are... and hopefully they are required tools for a SAAB Dealer.
If the Saab dealer doesn't have them... then I am **** out of luck.
Sucks... ALL I need to do is take the 2nd gear synchro off of one tranny and put it on another.
ANY HELP IS STILL APPRECIATED.
Last edited by USMCFieldMP; May 14, 2008 at 10:09 AM. Reason: Automerged Doublepost
Old May 14, 2008 | 11:24 AM
Josh@ottp's Avatar
http://saab.spx.com/hwtordr.asp You can order directly from here. Just let me know what kind of prices they give you as I'm curious.
Old May 14, 2008 | 05:58 PM
Thanks... I imagine they cost an arm and a leg... just as they are supposed to.
I'll call them tomorrow and see if they have them all available... the website lists them all available, except for the J-tool J 25031-A Three Jaw Puller... so we'll see.
Old May 14, 2008 | 06:07 PM
jimbos'ss's Avatar
good find!!
Old May 14, 2008 | 06:43 PM
yellowshowbalt's Avatar
well this is a shocker you do not needc any special tools to take apart any of are transmissions ive done 3 all ready and dident use a special tool one and dident chip not gear or dident scare any case but if you have the money to buy the tools go ahead and waist it its not my money.....
Old May 14, 2008 | 08:26 PM
  #36
Josh@ottp's Avatar
the only special tools you would need are the bushind drivers and any measurement tools
Old May 15, 2008 | 07:57 AM
  #37
You wanna come up here and do mine? I'll pay you.
And I wasn't planning on wasting my money on the tools. But I know absolutely nothing about trannies... so me doing it by myself is ABSOLUTELY out of the question. I'm just trying to find the tools to make my DEALERSHIP buy them. The same dealership whose trans EXPERT chipped the hell out of my 5th gear last time they took it apart.
EDIT:
The phone number listed on that site to buy the tools... is the same one that the dealership called... and they told the dealership that they had no idea what they were talking about.
The Service Manager read off the phone number and all the part numbers... exactly as they appeared on the web site. WTF. I'm gonna call Kent Moore today.
Evidentially... all the Dealership needs is:
87 92 129 Lifting Eye
87 91 303 Puller Arms, 150 mm
87 91 287 Puller
87 91 410 Output Shaft Protector
...and then they can operate.
Damn them. The Serv. Mang is calling a Saab Dealer right now.
Last edited by USMCFieldMP; May 15, 2008 at 07:59 AM. Reason: Automerged Doublepost
Old May 16, 2008 | 11:08 AM
  #38
Old May 29, 2012 | 06:48 PM
  #39
mongorat427's Avatar
I made my own
Oct 20, 2015 09:56 PM
Oct 13, 2015 09:32 PM
OrangeCoba
Oct 1, 2015 10:00 PM
Iceberg
Sep 28, 2015 01:31 PM
