transmission
Old Dec 2, 2009 | 07:05 PM
BLUE TRANSFORMER's Avatar
transmission
Ok tonight on my way home I was on the highway doing a normal drive, decided to down shift to 3rd gear from fourth to pass this car. Tried to go back to fourth a the motor reved up. So I went to 5th gear. At the next stop light rowed through the gears everything was fine. Is this a sympton of clutch slip...?
Old Dec 5, 2009 | 05:39 PM
girl loves cars's Avatar
when you're at a stoplight the transmission is not spinning so of course it will go from gear to gear without a problem. if you have the 2.2 engine, there have been other threads where users have been having problems with going from gear to gear, that is either clutch wear or damage synchros or worn synchros. if you can downshift without a problem but on the up shift you have problems, it could be that your linkage is jamming at that point and when you got to 5th it should be using the same links as when you go to 3rd, which may explain why you're not having the problem going 3rd to 5th. hope that helps!
Old Dec 5, 2009 | 06:58 PM
Cobalt_Daddy's Avatar
try going wide open throttle in 5th gear if the clutch is slipping you'll know it... if it doesn't you probably just need an adjustment somewhere. Note: this is a test that can be performed but shouldn't be repeated over and over... it can and probably will damage the clutch if it is done repeatedly. But trying it once shouldn't hurt it too much... good luck!
Old Dec 8, 2009 | 07:00 PM
I think the trans fluid got hot or is low, I am the second owner of this car. Time to inspect the car. Aprox 54,000 miles 05 ss/sc. Is royal purple good stuff or should I use Lucas products?
Old Dec 8, 2009 | 07:05 PM
ls1fbody's Avatar
Haz l33t wheelz.
use GM fluid. don't use RP, the trans doesn't do well with it over time.
Old Dec 8, 2009 | 09:18 PM
Not a problem with the gm stuff just asking around about the other fluids. I see speed network to much lol...
Old Dec 9, 2009 | 12:33 AM
Black SS 07's Avatar
probably just the roll pin goin... 2, 4, and reverse are usually first to go. simple 15 min change.
Old Jan 13, 2010 | 09:46 PM
Bringing this post back from the dead pool. Saw my buddy on the hwy.
He has a Lexus IS-F no mods, Me I put on the OTTP stage 2 kit. We were crusing side by side I was in fourth down shifted to 3rd stomped on the gas took it up to 6000rpm and the damn **** happened again. I think my clutch is shot. Now my ? I have a non g85 car. Threre are 2 styles of clutches fo rour cars sac and non sac. Sorry tried to search. What do we have. Good bad or ugly. Need input....Sorry forgot to say tried going to 4th and the motor reved up again..
Old Jan 15, 2010 | 11:02 PM
Maven's Avatar
its highly unlikey its your clutch.
Its possibll the roll pin.
Its very possibly poor technique
it could be 4th gear blocker ring wear.
Old Jan 17, 2010 | 08:03 PM
Roll pin good reply..
Technique are you talking about my driving style.
Back to replys #1 and #3 will look into that this week..
Peace out Maven.. Oh still looking for a clutch and flywheel...
RaginChopsuey
Oct 27, 2015 01:27 PM
importkiller
Sep 30, 2015 07:18 PM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
