transmission bolts
Old Feb 16, 2016 | 12:54 AM
exninja's Avatar
Originally Posted by tomj77
mine had that bolt it is the same size, but it uses a 13mm wrench. unless the shop who put my clutch in used a 13mm instead of 18.. the head is 13mm the bolt itself is the same size and thread as the rest of the 18 mm bolts
Very possible they put an extra bolt in then.
Old Feb 21, 2017 | 01:32 PM
Dennis461's Avatar
Old thread, brought back to life.
Took me two hours to find the last bolt on my 2006 Cobalt LT with 2.2 motor.
NINE bolts in all through motor to tranny.
Marked them with a black X in photo.
I could not have done this without taking the exhaust manifold off.
[/QUOTE]
Old Feb 21, 2017 | 01:57 PM
royce777's Avatar
^ I believe if its a auto it has more bolts that hold the trans to the block.
Old Mar 1, 2017 | 09:50 PM
63 Nova SS's Avatar
Yep
Old Mar 16, 2020 | 03:13 AM
Jstead93's Avatar
Cant figure out how many bolts hold the transmission to the engine. I have an 06 ss. 5-speed manual. Front wheel drive. 2.4. I found 6 bolts cant find the rest
Old Mar 16, 2020 | 08:28 AM
Did you get the one behind the starter?
Old Mar 16, 2020 | 11:24 AM
USMCFieldMP's Avatar
Rattlesnake Race Shop
Or the one under the t-stat housing? It screws in on the block side, not the transmission side.
SSLOW06
Oct 1, 2015 07:21 PM
Tupp
Sep 30, 2015 08:18 PM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
