Transmission Cooler
Old Jun 4, 2007 | 04:29 PM
OrngBalt's Avatar
Transmission Cooler
Ok, so I talked to Cobaltic today about this real quick and he is installing one. Has anyone else installed one of these? It looks pretty inexpensive, and if it saves the life of my transmission, then sounds amazing.
Who has one? What kind did you get? How was the install?
Old Jun 4, 2007 | 07:42 PM
TVS_SS's Avatar
You should be able to pick one up from the local hardwarestore..
Old Jun 4, 2007 | 07:44 PM
NJHK's Avatar
http://www.ecotecforum.com/forums/showthread.php?t=1510
There is a how to that you can thank Ppazz on.
Old Jun 4, 2007 | 08:37 PM
celicacobalt's Avatar
i have a long tube permacool one from summitt and it works great, temps hardly ever go over 180 degrees
Old Jun 5, 2007 | 02:47 AM
HunterKiller89's Avatar
hayden holds an amazing reputation, though i havent installed mine...they have coolers for all sizes/loads
Old Jun 27, 2007 | 06:35 PM
cougar2588's Avatar
when u get it, let me know what kind u got, and how the install went. im definately gunna get one after today. really hot/humid day here in michigan, driving around all day with the temp reading 200-205 was just pissing me off.
the how to made it look pretty straight forward, but then again, everything is easy when ur reading and looking at pictures.
Old Jun 27, 2007 | 06:48 PM
BlackLS's Avatar
I am having a B&M Supercooler installed this weekend so I'll let you know how the install goes and then I should be able to answer any other questions.
Old Jun 27, 2007 | 06:53 PM
Psykostevo's Avatar
SSFamilyWagon, did it too
Old Jun 27, 2007 | 07:30 PM
cougar2588's Avatar
how much did that cost? and are u installing it urself?
Last edited by cougar2588; Jun 27, 2007 at 07:31 PM. Reason: Automerged Doublepost
Old Jun 28, 2007 | 09:51 AM
iLLmaTic3s's Avatar
i just put mine in about two weeks ago. ill get pics soon. it costed me about 70 bucks. it looks sick.and thos temps u getting are ur engine temps. sometimes ur tranny can get that hot, but the tranny cooler is a goiod idea if ur running a tune on that tranny.
Old Jun 30, 2007 | 01:23 PM
sushidog's Avatar
I just slipped a meduim sized Hayden on my 2.4 today. I see where to add tranny fluid, but I can't figure out how to check the fluid level. The owners manual is no help. All it says is don't check it, bring it in to a dealer if it is leaking. There's usually a little weep hole, but I can't find the bolt.
What do you think the capacity of a medium sized, plate type trans cooler is (with about 5ft of lines?) I hardly lost any fluid at all on the install (Thanks PpaZz!).
I hate to just add a little fluid blindly, but if I must, do you think a pint sounds about right?
RaginChopsuey
Oct 27, 2015 01:27 PM
importkiller
Sep 30, 2015 07:18 PM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
