Transmission Ringing Noise (While Driving)
Old May 26, 2013 | 01:00 PM
zwk2013's Avatar
I tried to do some research/reading and couldn't find much.
My transmission makes a slight yet noticeable sound while driving. The best way to describe it, is almost like a loose chain sound. Around 3k rpm's (second gear) and let off and it will hop a little hard and you can really hear it.
Any ideas? Is this completely normal?
I thought I read somewhere it was the syncros going bad, and somewhere else it was normal. Just looking for some opinions or experiences please.
Thanks
Old May 26, 2013 | 02:40 PM
mongorat427's Avatar
Could be the bearings going bad. They will whine when you let up
Old May 26, 2013 | 03:25 PM
cmiller8006's Avatar
Stock tranny or is it a zzp one? ZZP's makes noise anyway since the tolerances are closer, like mongo said bearings could be going bad if its a stock one.
Old May 26, 2013 | 03:34 PM
zwk2013's Avatar
Stock transmission
Old May 26, 2013 | 03:45 PM
zwk2013's Avatar
Also, only 54,000 miles. Seems premature. Anyone know if this is something covered under power train? 5yr 100k good until August of this year.
Old May 26, 2013 | 07:18 PM
buildmeanempire's Avatar
Trans will be covered under powertrain.
Hey mongo, when you say bearings are you talking about the input shaft bearing? Mine makes a grinding noise when I coast in gear.
Old May 29, 2013 | 04:29 PM
SaberD's Avatar
I've noticed mine ringing a little under slight load on the highway. You may want to try changing the fluid. I haven't changed my fluid in a good 20k miles, and I drive it pretty hard. It's probably due for a change.
Also try pushing in the clutch to see if the noise remains.
Old May 29, 2013 | 04:52 PM
SS89's Avatar
Mine does that when I let go the gas pedal and I'm driving near a concrete wall, sounds like a chain (krrrrkrrrrkrrr)
Old May 30, 2013 | 09:10 AM
Gelladuga69's Avatar
Supposedly that's the clutch. Couple threads on this about a noise on decel.
Old May 30, 2013 | 09:19 AM
Chain in the tranny prolly. The clutch will be heard when stopped with the car in neutral most of the time
Old May 31, 2013 | 01:06 PM
zwk2013's Avatar
Mine does that too. It's annoying. Is it the tranny or clutch?
One says clutch, one says tranny. Which one is it most likely?
Old May 31, 2013 | 01:14 PM
Check out other threads. There's a bunch on this.
RaginChopsuey
Oct 27, 2015 01:27 PM
biniecki
Oct 25, 2015 02:23 PM
jimbofug007
Oct 2, 2015 12:06 PM
Trav3480
Oct 1, 2015 08:17 PM
