Where can I get a 25921572 intermediate shaft assembly or just the shaft for MU3 LSJ?
Old 06-13-2020, 10:30 PM
hatrik8's Avatar
My intermediate shaft bearing blew out today. I pulled the PS axle along with the intermediate shaft and there is no way I am getting them apart. They are basically fused. I guess that's to be expected with 270k+ miles... What's left of the bearing is also fused into the bracket.
So I need an axle, intermediate shaft, intermediate shaft bearing bracket, retainer ring, clips(most likely), and also a new wheel hub assembly. I can find just about everything I need except the shaft.
I haven't been able to find one on the web. Does anyone have a suggestion?
CED had what I needed, but it's discontinued on their site.
Cobalt, ION Intermediate Shaft Kit 25921572
Does the SAAB 9186588 shaft work?
I need to get my car fixed because my wife's POS Chrysler minivan transmission went with 70k miles a couple weeks after warranty expired.
Old 06-14-2020, 06:48 AM
blu3_v1p3r's Avatar
I just looked at rockauto, and gm parts direct and nothing. Have you checked places like NAPA?
Old 06-14-2020, 09:11 PM
Monieg5gt's Avatar
I'm afraid your only other option if you can't fine new is to look for used parts from the junkyard. I've gotten a lot of good parts for my supercharge build i'm doing for my g5. Try these guys here for good used parts.
https://www.car-part.com/index.htm
Old 06-15-2020, 07:22 AM
blu3_v1p3r's Avatar
If i'm not mistaken, the intermediate shaft if the same between the SS/SC and SS/TC.
Old 06-15-2020, 08:35 AM
spline count is different iirc
OP email Tom at CED and he might be able to steer you in the right direction.
Old 06-15-2020, 03:44 PM
exninja's Avatar
Spline count is different at the CV axles/hub interface, but they are the same inboard
Old 06-15-2020, 03:49 PM
Ok I couldn't remember if the inner was the same or not
Old 06-16-2020, 02:05 PM
hatrik8's Avatar
I found a spare from someone on FB.
If it is for a TC can I just swap in an axle from a TC?
Edit: Never mind I just re-read what you wrote....didn't register the first time...haha. Also searched the forum about the axle differences.
LSJ and LNF axles are the same inboard at the transmission and intermediate shaft. They differ in shaft thickness and spline count at the wheel hub
Old 06-18-2020, 02:57 PM
Rattlesnake Race Shop
USMCFieldMP's Avatar
NAPA has really good LSJ axles and they're quite cheap. Bonus discount on them if you have AAA (you really should; the towing makes it so worth it).
A lot of vendors repackage the NAPA axles as "Stage 1" axles.
EDIT: before you assemble, coat the splines on the axle to intermediate shaft with anti-seize. The intermediate shaft doesn't actually seal to the axle, so what happens is water gets in there and it rusts... that's why the axles always seem so gotdamn hard to separate from the intermediate shaft.
Old 06-18-2020, 03:09 PM
Solid tip, I had never thought of that. I'll be doing that when I have the sub frame dropped for clutch and engine work next monthish
Old 06-19-2020, 09:42 AM
blu3_v1p3r's Avatar
Napa also had good LNF axles from what I had heard, but they seem to be out of stock on them. I also heard that they are lifetime warranty on them... so if you break one you can swap it for a new one.....
Old 07-14-2020, 08:28 AM
hatrik8's Avatar
I ended up pulling the axle that I got off amazon and replacing it with a Napa axle. The amazon one I think it was Cardone and gave me a vibration under acceleration. The Napa axle works perfectly fine.
Here's some part numbers for future reference.
axle shaft bracket 12788651 $116 gmpartsdirect
axle shaft 25921572 discontinued
axle shaft bearing 12785906 $62 gmpartsdirect
axle shaft retainer ring 12789486 $15 gmpartsdirect
19351859 Replaces 88862472 Manual Transmission Fluid (SAE 75W-85) (API GL/4) (1 QT).946L A 5-SPD MAN/TRANS(MU3
Old 07-14-2020, 09:03 AM
blu3_v1p3r's Avatar
aslo to make it easier.
https://www.gmpartsdirect.com/auto-p...ive-axles-scat
Old 10-05-2020, 07:00 PM
Wolverage's Avatar
Hey everyone. Im in the same boat looking for an intermediate drive shaft for an 05 RL. When to replace the axles the other day and the right side seems fused with the shaft and im not sure how else to try and get them apart. Did anyone ever find how to locate a new one?
Old 10-05-2020, 07:01 PM
Wolverage's Avatar
Did you ever locate a new intermediate driveshaft? I'm in the same boat and can't find them anywhere.
Old 10-11-2020, 08:04 PM
DeanSsspsh's Avatar
Mongorat on face book has a bunch of rebuilt intermediate shafts. I just bought one. $85 shipped
Old 10-12-2020, 04:47 PM
Wolverage's Avatar
Do you have a link to his Facebook page? I tried searching mongorat and didn't find anyone with that name.
Old 10-13-2020, 12:22 PM
DeanSsspsh's Avatar
https://www.facebook.com/groups/5425...8249/?sfnsn=mo
That's The link. It's a cobalt ss parts group on f.b. You might have to join
Old 10-14-2020, 07:39 AM
bahoodle's Avatar
facebook marketplace is gonna become your best friend for the cobalt lol
Old 10-15-2020, 03:41 PM
hatrik8's Avatar
Sorry I didn't see this until now.
I did get a used one on facebook like others have suggested.
jdoginc
05-22-2018 11:07 PM
bigmd
07-30-2010 08:43 AM
bigmd
07-25-2010 01:30 PM
scotch89
01-13-2010 11:18 PM
zzzzzzzz
08-05-2006 04:08 PM
Quick Reply: Where can I get a 25921572 intermediate shaft assembly or just the shaft for MU3 LSJ?
