ZEX plugs 82003-4
ZEX plugs 82003-4
Just want to say thanks to those that recommended ZEX plugs.
I was running the NGK IX plugs and my car ran like crap. These plugs come gapped to 0.35. I dropped them in, went for a cruz to Canmore and back (roughly 250 km) and the car ran beautifully.
All i can say about these plugs is
Damb
1. startup = smooth
2. engine idle = smooth
3. Throttle response = Holly Mother of God
4. acceleration from a stop = smooth but quick
5. response between shifts = smooth with no hesitation
6. supper charger response at 2000 to 3000 RPM = impressive and smooth
7. boost gains over IX plugs = was 80kPa (11.6 psi) consistantly to 100 kPa (14.5 psi) consistantly (also see #3)
8. For the price $25 (CAD) I don't mind changing them every couple of oil changes.
These plugs are
in my books and are the only plugs for my car unless an act of god happens or the Flux capasitor is the new replacement.
I would highly recommend these to anyone seeing as there is alot of confusion as to what gap is good for what applications and seeing as not every one car is the same or set up the same this is just a suggestion. They worked for me and a few others with similar mods so maybe they will work for others.
I am not sure where they can be found in the states but in Alberta or BC
they can be found at Mopac. Just give them the number quoted in the title. I paid around $25 CAD.
Here is the link to the addresses.
http://www.mopacautosupply.com/main.html
Sorry. Thiss post was suposed to be in Performance 2.0. I don't know what happend.
Damb
1. startup = smooth
These plugs are
in my books and are the only plugs for my car unless an act of god happens or the Flux capasitor is the new replacement.I would highly recommend these to anyone seeing as there is alot of confusion as to what gap is good for what applications and seeing as not every one car is the same or set up the same this is just a suggestion. They worked for me and a few others with similar mods so maybe they will work for others.
they can be found at Mopac. Just give them the number quoted in the title. I paid around $25 CAD.Here is the link to the addresses.
We have now added this into our catalog. Thanks for the heads up guys.
http://www.cobaltperformanceparts.co...roducts_id=309
They do. It says 2.0.
They were polite and left out the part about not being able to put them into shitbox's.
These are quality plugs. I am sure once the word spreads more people are going to get them.
http://www.cobaltperformanceparts.co...duc ts_id=309
I USED TO WORK AT MOPAC IN EDMONTON .....major rippppppppp offffffff thhheeeerrreeeeeee ....60% mark up ftw!
i believe they are once step colder, someone confirm? they are 2 steps colder the stock like the IX's and one colder then tyhe 7's arent they?
Last edited by mattyfinch; Jan 31, 2007 at 09:55 AM. Reason: Automerged Doublepost
agentirons
Oct 16, 2015 02:11 AM
