zzp rotated trans mounts
Old Jul 20, 2011 | 02:44 PM
goeckeritz123's Avatar
Hey guy i just got these installed amd they vibrate a bunch on start up and 1st gear is bed and even with the ac on it vibrates more is this normal. I like how they make the car handle
Old Jul 20, 2011 | 02:48 PM
BartSS's Avatar
You install them yourself cus my PRS ones barely make mine vibrate at all
Old Jul 20, 2011 | 02:49 PM
Bl4des's Avatar
try to loosen up all you mounts a little including the motor mount
then shake the motor then retighten all the mounts
Old Jul 20, 2011 | 05:33 PM
So just loosen up all the mounts and shake the motor a couple times then what should i torx them down to
Old Jul 20, 2011 | 07:47 PM
Boosted05's Avatar
They will shake like a bitch for about 2 weeks, once you get them broken in they will be fine. I only put the rear mount on my car but it was horrible the first little bit lol.
Old Jul 21, 2011 | 12:33 AM
Guess i need to break them in lol
Old Jul 21, 2011 | 01:08 PM
brainchasm's Avatar
Upper engine mount:
(2) 18mm bolts - 74ft-lbs
(3) 15mm bolts - 37ft-lbs
Front trans mount:
(1) 18mm through bolt - 74ft-lbs
Mount to trans - 66ft-lbs
Rear trans mount:
(3) 18mm bolts - 37ft-lbs
Mount to frame - 44ft-lbs
Through bolt - 74ft-lbs
Old Jul 21, 2011 | 05:47 PM
Thanks for the specs brotha
Old Jul 28, 2011 | 03:23 PM
I torx the three bolts on the rear trans mount and it broke
Old Jul 29, 2011 | 09:57 PM
Boosted05's Avatar
The bolt I hope? You should be able to pull the mount back out and easy out it. Get new bolts from the dealer and you will be ok.
Jan 12, 2016 12:01 AM
no_ss
Oct 18, 2015 11:58 PM
justinchinn
Oct 2, 2015 12:18 PM
OrangeCoba
Oct 1, 2015 10:00 PM
