Fastest LNF ???
Fastest LNF ???
So for awhile I have been posting here and there about my friends LNF build we were building at the same time but i ended up deploying. His build is darton sleeves, wiseco pistons, carrillo rods, PTE 6262 dbb not sure of ar. with FBO. so he dynoed the other day on race gas i believe and put down 626hp. heres the sheet. Im not sure if this is the highest HP for a lnf but i am impressed with him and now im considering the upgrade more for my 5857dbb.:
this is also a 2010 SS coupe. believe boost was at 28psi timing im not sure and there r no fuel mods besides S1 cams. full treadstone kit w/o the intercooler we are both running hahn intercoolers.
impresive numbers. id like to see a different graph where it shows powerband by rpms and afrs. although the graph shows the power curve id still like to see it in rpms lol.
what did he do about fueling? 5th injector etc?
he does not run that on the street from wut i hear and srry bout the thread i was thinking the lnf putting down most power, from wut we talked bout on fb he just wanted to see where his build was at, he is running 20psi on the street, fuel mods are none and srry thats the only graph he posted. i can ask if he has any.
I'm by no means calling you a liar, but I just find it really hard to believe with that much power being made.
nope, that's actually very common. Large turbos are notorious for making quite a bit less torque than hp, especially on a 4banger.
no fueling mods???? Not even cams with an upgraded fuel lobe??
I'm by no means calling you a liar, but i just find it really hard to believe with that much power being made.
very solid numbers for sure. but yeah zzp is in the 700s
interested on the fuel used though
Last edited by EXsoccer1921; Aug 27, 2012 at 04:56 PM. Reason: Automerged Doublepost
Looks to be a 3rd gear pull. If I remember right 112mph is about 6500/6600rpm
