Dyno Results Dyno pictures, videos and dyno results.
Hahn s20g true results
Old May 21, 2012 | 01:38 AM
Chevycobaltss3's Avatar
I shoulda done a e tune but I felt it would be better for our community to see the baseline **** pump gas
Old May 21, 2012 | 02:01 AM
40rty's Avatar
Is your motor built?
Old May 21, 2012 | 02:05 AM
Darton sleeves, wiesco, Carrillo Rods so yes.. I had the. T67 td07/td06sh setup on before but it fucked up and changed to a 20g but with a little larger wheels . But I got rid of that to get the regular 20g stuff
Old May 21, 2012 | 08:21 AM
40rty's Avatar
Can you post some logs?
Old May 21, 2012 | 08:30 AM
No longer on 89/91 lol But if I do it again I will. Anything specific u want to see?
Old May 21, 2012 | 08:41 AM
HHRSSouth's Avatar
Looks like TD06H-20g numbers to me?
Is this the actual TD06H-20g that came in it or is this with an upgraded compressor wheel you were talking about, 25g I think you said?
is it the 10cm2 hotside, I think thats what the Hahn S20g originally came with ? If so, try and put a smaller hotside on for a TD06H wheel, there are 8cm2 out there that would spool faster and still give you your redline.
Old May 21, 2012 | 08:49 AM
It's directly Hahns turbo. No modifications, I believe it's the 8Cm2
Old May 21, 2012 | 09:54 AM
vahdyx's Avatar
James does the Hahn flow more than BNR. I'm assuming it flows more than K04+
Old May 21, 2012 | 10:27 AM
Fastgti69's Avatar
Amazing bro, these are great numbers. i would totally be happy with power like this.
Old May 21, 2012 | 10:45 AM
elecblue06's Avatar
being he said about 450 whp on 28 psi and e47 it seems like it would be right around the same flow
Old May 21, 2012 | 10:52 AM
  #36
Up top the 20gholds it's efficiency better. But both turbos flow peak flow about the same but overall the two are very similar . When I tuned team Ss and he made 432 on e47 on 24 steady 25 spike he flowed great. I'm wanting to get another dyno done at the same dyno for comparison for e vs the low octane. ... Because what I'd do is raise boost to say 28 spike and 26 steady and see power difference
Old May 21, 2012 | 10:56 AM
  #37
Kahless's Avatar
24-26 is low boost these days?? jeez. nice flat curves tho
Old May 21, 2012 | 11:03 AM
  #38
Lol for the 9:3.1 compression yes lol.. My high boost on previous turbo was 33 with spike 35 lol
Old May 21, 2012 | 11:30 PM
  #39
mightymouse1975's Avatar
thank you for doing this. this is more of a "real world" test. there is ONE gas station with E within a 40 mile radius of me. so me staying on 93 would be the way to go for me. hell i wonder what vinces tune looks like since he and hahn started working together. i planned on getting this turbo this year despite the nay sayers... point is DIRECT BOLT ON AND MORE POWER. no need for a manifold and other parts. thanks again!!!
Old May 21, 2012 | 11:37 PM
  #40
vahdyx's Avatar
Well, I can't look back now. No one remind me I paid the same price for a turbo that does way less. At least mine is a true bolt on...
Old May 21, 2012 | 11:41 PM
  #41
your welcome. I did put 4.5 gallons in the tank with the rest of the gas i had and filled it up with 93 octane on the way home today and i leaned it out and put bost to 27 lbs and timing to 26 from 4ktill full redline.. i wanted to check to see if i could handle it, and it wouldnt handle the quicker ramo ( fuel pressure was giving) so i rampled it slower and turned boost down to 26 and it worked) next time ill dyno on a e mix...
Old May 22, 2012 | 12:11 AM
  #42
alerosaint's Avatar
20g very tempting
Old May 22, 2012 | 12:30 AM
  #43
FrossB's Avatar
Thread Killer
dang i make a little more than that on $5000 kit lol then again mine isn't even close to maxed out
Old May 22, 2012 | 12:56 AM
  #44
Yea the 20g is maxed at 30 spike 28 steady like the bnr. And Bryce your more conserve then I.. Mainly due to ure shittier fuel I guess lol
Old May 22, 2012 | 01:17 AM
  #45
40rty's Avatar
VE and see the cleanness up top at peak power, waste gate duty cycle too.
How long do you plan to keep the turbo on your car for? Is this a permanent upgrade? If so please provide us with pics currently and after about 3-4 months of it on and use. Thanks
Old May 22, 2012 | 01:18 AM
  #46
FrossB's Avatar
Thread Killer
dont talk about my fuel like that! ill steal your moth antenna for myself! haha if i could only run E!!!!
Old May 22, 2012 | 01:44 AM
  #47
K, I'll give yuh screen prints of the tune that was on it. Timing, wgdc, mals, and etc.
I've already sold my previous wheels and etc so this wil stay on for a bit
Old May 22, 2012 | 01:55 AM
  #48
FrossB's Avatar
Thread Killer
such a stand up individual you are James!
Old May 22, 2012 | 05:39 AM
  #49
40rty's Avatar
Hey James, you should race one of our Big turbo Sky's that we have in Kentucky. From a dig
Old May 22, 2012 | 08:55 AM
  #50
Who do you have in ky, iced tuned like 15-20 here but all were stock turbo. And **** digs hahaha... Sin spin spin
