Dyno Results Dyno pictures, videos and dyno results.
OFFICIAL Dyno Thread (take two)
Old Mar 19, 2009 | 05:21 PM
  #426
drew1991sf's Avatar
alright i'll see if they can do a bunch of pulls cuz they said 3pulls for 85
Old Mar 20, 2009 | 02:44 AM
  #427
stryder's Avatar
that is why i never posted dyno numbers or anything for my car. (the balt) I know what it had and thats good enough for me. good numbers from that TVS though.
Old Mar 20, 2009 | 03:15 PM
  #428
NWAE Cobalt's Avatar
I think we need to add a few things to the list:
compression ratio if raised
engine and tranny mounts as they add traction and get the 60' down
what stg cams are in instead of just "cams" maybe a number such as C2 for cams stage 2 or something
lightweight alternator pulley and crank pulley (they make a lightweight stock sized one as well as te underdrive)
and lsj injectors
Old Mar 20, 2009 | 06:59 PM
  #429
EXsoccer1921's Avatar
...oooooooooooooor if people are curious they can ask
Old Mar 20, 2009 | 08:21 PM
  #430
ColeJJones's Avatar
Bannned
dont need to add tranny/engine mounts to the list... nothing to do with hp. but if this was the 1/4 1/8 thread thenyes
Old Mar 21, 2009 | 01:39 AM
  #431
i'm pretty sure he's confused lol
Old Mar 21, 2009 | 12:08 PM
  #432
Terminator2's Avatar
Originally Posted by elecblue06
if you dont blow me away.. i cry HOWEVER people might be in love with trifecta lol
The only numbers I remember are the SAE. corrected ones 338 whp and 330 wrtq. STD. corrected was approx 352 whp and 345 wtrq. The peak HP is way up around 6700 RPMs now and the torque gains up top are amazing. The power does not drop off at all really. It used to fall off real bad up high not anymore. It is over 300 wtrq from about 3K to 6K RPMs now. I made 242 whp and 236 wtrq SAE stock, 253 whp 247 wtrq STD Stock. 293 whp 316 wtrq SAE Tune only, 307 whp 330 wtrq STD. Tune only. All runs done on the the same dyno, same operator, same load. Dynocom dyno. I have my stock vs tune only sheets in my gallery, but still waiting for my tuner to email me my new sheets. Yes, I know my torque is kinda low but the smoothing is crazy on the graphs no peaks or valleys really. How many others have made just 236 wtrq SAE stock? Most others are 20 ft-lbs higher. I attribute that to the fact that the dyno is a loaded one and the drum takes more initial twist to start rotating. Either way you slice it the gains are tremendous. About 100 whp and 94 wtrq over stock
Old Mar 21, 2009 | 12:16 PM
  #433
Area47's Avatar
Rent me! per hour
now you're starting to understand how it works on the top end. what were the ms of the injectors zinging it that high?
Old Mar 21, 2009 | 01:00 PM
  #434
5.2 ms injection time max. Injection window appox 5ms so I am still ok there I think. I just cannot believe how well this thing flows up high now. 37.6 lbs/min airmass at 6700 rpms, and I am still on the stock intercooler. Tune only was appox 32lbs/min. Stock was 27.8 lbs/min or so.
Old Mar 21, 2009 | 01:04 PM
  #435
ralliartist's Avatar
that's definitely impressive. Wonder if you could eek out another 2lbs/min and come close to 40lbs/min if you ported the turbo.
If you wanted a bit more top end, you could clip the turbine wheel.
I need to get an LNF. Maybe when I get back from germany.
Old Mar 21, 2009 | 01:17 PM
  #436
I am not sure but I dont not want to play guinea pig in this case too expensive if the stock turbo gets messed up. I wonder If just porting the exducer housing would help any. You should swap an LNF into your car.
Old Mar 21, 2009 | 01:24 PM
  #437
haha, no. No swapping. I like my LSJ.
Old Mar 21, 2009 | 01:25 PM
  #438
Black08SSTC's Avatar
Here you go, just swap it out lol
http://cgi.ebay.com/ebaymotors/Chevy...spagenameZWDVW
Old Mar 21, 2009 | 01:26 PM
  #439
No..
Old Mar 21, 2009 | 02:49 PM
  #440
drew1991sf's Avatar
i made 215/210 on a dyno jet, they said theres dyno reads low like a mustang dyno.
Old Mar 21, 2009 | 02:54 PM
  #441
How much air are you flowing? That will give you a more realistic idea on your true HP.
Old Mar 21, 2009 | 02:59 PM
  #442
drew1991sf's Avatar
? wats that mean? they also said my air to fuel ratio is now like 13 or 14
o and i messed up on tq it was 202
Last edited by drew1991sf; Mar 21, 2009 at 02:59 PM. Reason: Automerged Doublepost
Old Mar 21, 2009 | 03:02 PM
  #443
lsjwannabe's Avatar
That can be easily skewed as well. I have logs saying i was doing 52lb/min at 6k rpms
Old Mar 21, 2009 | 03:03 PM
  #444
revhigh18's Avatar
damn some one beat me
Old Mar 21, 2009 | 03:04 PM
  #445
drew1991sf's Avatar
but im gettin re-dyno'd after i get my stage 1 from ottp. to see how the tune is on my car and if the place im dynoing at needs to change anything
Old Mar 21, 2009 | 04:14 PM
  #446
I dont think it is. The numbers are fairly representative. The MAF error is only 2%. Stock it flowed approx 27 lbs./min which is enough to support approx 260-270 engine hp. Tuned it flowed 32 lbs/min. which is enough to support aprox. 310-320 engine hp. makes sense if you look at all my max flow numbers vs the hp I made at the wheels.
Want to see my STD. numbers? They are insane.
Last edited by Terminator2; Mar 21, 2009 at 04:21 PM. Reason: Automerged Doublepost
Old Mar 21, 2009 | 07:33 PM
  #447
revhigh18's Avatar
i dont really car too much about dyno numbers any more i am a track times kinda guy
Old Mar 21, 2009 | 11:25 PM
  #448
elecblue06's Avatar
ok you blew me away.. and i think trifecta is going to have ALOT of nut swingers lol good **** terminator2... now get some tires.. and get to the track
Old Mar 22, 2009 | 12:19 AM
  #449
drew1991sf's Avatar
dont u have to turn something off on our cars when we dyno?
Old Mar 22, 2009 | 12:41 AM
  #450
MP81's Avatar
No...unless you're running the A/C, the stereo and the defroster...
