after market radio install?
i searched and i found what all the wires were for a 2005 cobalt but would it be the same for a 2007 cobalt since they changed the wireharness? i also looked for a how to maybe i just missed it any help?
thanks
anyone?
thanks
anyone?
Last edited by 07cobalt4life; 11-21-2008 at 03:42 PM. Reason: Automerged Doublepost
the 2007 has a different harness i do beleive. cuz it has the different radio that has the display under the gauges or something?? i have an 08 and used an 07 cobalt wire harness but couldnt use an 05.
no i know ther different one has one plug in and the 2007 has 2 plug ins i just wanted to know if they were the same color code because i found this https://www.cobaltss.net/forums/electronics-audio-video-49/cobalt-audio-pinouts-2823/
http://www.modifiedlife.com/2007-che...iring-diagram/ im thinking this is what i want?
anyone?
anyone?
Last edited by 07cobalt4life; 11-21-2008 at 04:35 PM. Reason: Automerged Doublepost
2007's have a different system thus the need for the GMOS LAN 04.
In all honesty I have the GMOS and its not worth the $$
If you don't mind loosing the turn signal chime the warning chimes and the RAP
The problem is that an aftermarket deck uses RCA's and the GMOS adds RCA'a to the harness so they can plug into the aftermarket HU and run the stock amp
Just use the Metra 70-2202 and follow th instructions that come with it the wires should be labeled.
I say this cuz I think what your getting at is that your cutting your stock harness. If so don't do it guy, the 70-2202 is like $15-20 and well worth it
Forget it just read the above post, and i tried to look up the 07 wire chart and can't find it
What is the make and model of your harness
BTW-That chart at modedlife is for non Pioneer set ups
agentirons
10-16-2015 02:11 AM
Delta coupe
09-30-2015 08:11 AM
