aftermarket radio install help
im buying a single din radio and i want to know if this kit Stereo Radio install Mount Dash Kit +Wire Harness Plug | eBay would work properly. I have the pioneer system and i heard that an aftermarket radio will cause problems with the stock sub. Is that true? and also whats the red wire in the pic for?
Yes that is right! The red wire is your accessory wire... It goes from the Wiring harness to the Amp turn on wire to turn on your stock amp, i believe it's blue or green... but don't quote me on that!
As for messing it up, it wont.. you just have to have that amp turn on lead go to the stock amp power turn on.
You will also lose function of your steering wheel controls.
kit will work. the red wire is for dropping ignition from the aftermarket radio to the passenger side console panel near the BCM (ign wire is generally thick gauge pink).
as for the harness...what year is your balt and does it have onstar?
05, no onstar, pioneer system with sub
lol and idc about steering wheels controls because i RARELY use them
Yah if you were to wire up everything on the harness, to your aftermarket deck harness, you would have no sound as your stock amp will not turn on.
So you need to run the "Remote Wire" which is blue on the harness, to the stock deck turn on lead.
Ill find a wiring diagram for you.
Car Radio Battery Constant 12v+ Wire: Red/White
Car Radio Accessory Switched 12v+ Wire: GMLAN Serial Data
Car Radio Ground Wire: Black/White
Car Stereo Antenna Trigger Wire: Yellow
Car Stereo Amp Trigger Wire: Pink
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
So Basically, you connect the blue and pink wire together, and tap into a 12+ accesory (sp) wire to power the stock amp, that's what i did with mine.
I didn't hook up the pink wire and everything works just fine in my car. I have the pioneer system also. My new HU came with an amp wire to hook up to a stock amp so I guess that's y it works. It's a blue wire.
yup if u get the right harness then u dont have to worry abotu any of that you just install like normal other then the red acc which goes to the fusebox bypassing the stock wiring and your done
there is no where else to run it. I mean not easily... the gm lan is data not 12v acc so taping that would never get your radio to turn on (and opens a whole bunch of problems if you put power to it) You dont have to run it to the fuse box you can tap any 12v acc wire but you want to make sure its something like an accessory not main function of the car and that whatever you are tapping can handle the additional load unless you are wiring up a relay
agentirons
Oct 16, 2015 02:11 AM
