aftermarket radio install help
Old Jan 28, 2012 | 07:37 PM
Pepsi's Avatar
im buying a single din radio and i want to know if this kit Stereo Radio install Mount Dash Kit +Wire Harness Plug | eBay would work properly. I have the pioneer system and i heard that an aftermarket radio will cause problems with the stock sub. Is that true? and also whats the red wire in the pic for?
Old Jan 28, 2012 | 07:39 PM
CannonBalt's Avatar
Yes that is right! The red wire is your accessory wire... It goes from the Wiring harness to the Amp turn on wire to turn on your stock amp, i believe it's blue or green... but don't quote me on that!
As for messing it up, it wont.. you just have to have that amp turn on lead go to the stock amp power turn on.
You will also lose function of your steering wheel controls.
Old Jan 28, 2012 | 07:40 PM
c4w18's Avatar
kit will work. the red wire is for dropping ignition from the aftermarket radio to the passenger side console panel near the BCM (ign wire is generally thick gauge pink).
as for the harness...what year is your balt and does it have onstar?
Old Jan 28, 2012 | 07:44 PM
Pepsi's Avatar
05, no onstar, pioneer system with sub
Old Jan 28, 2012 | 07:45 PM
Pepsi's Avatar
i hook the red in the amp power wire?
lol and idc about steering wheels controls because i RARELY use them
Old Jan 28, 2012 | 07:46 PM
CannonBalt's Avatar
Yah if you were to wire up everything on the harness, to your aftermarket deck harness, you would have no sound as your stock amp will not turn on.
So you need to run the "Remote Wire" which is blue on the harness, to the stock deck turn on lead.
Ill find a wiring diagram for you.
Car Radio Battery Constant 12v+ Wire: Red/White
Car Radio Accessory Switched 12v+ Wire: GMLAN Serial Data
Car Radio Ground Wire: Black/White
Car Stereo Antenna Trigger Wire: Yellow
Car Stereo Amp Trigger Wire: Pink
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
So Basically, you connect the blue and pink wire together, and tap into a 12+ accesory (sp) wire to power the stock amp, that's what i did with mine.
Old Jan 28, 2012 | 07:52 PM
Pepsi's Avatar
Ok i know what that wire is for now, thanks alot guys. And will the pioneer sub still work if i install a aftermarket hu?
Old Jan 28, 2012 | 08:07 PM
CannonBalt's Avatar
It sure will! As long as you get power to the stock amp, your sub will fire up (As it's wired into the stock amp)
Old Jan 29, 2012 | 03:11 AM
EmperorJJ1's Avatar
exactly the stock amp powers all the speakers so u either get all or no sound really
lastly it might be a good idea to look into metra kit and harness. antenna adapter doesnt matter
Old Feb 1, 2012 | 11:50 PM
Pepsi's Avatar
I didn't hook up the pink wire and everything works just fine in my car. I have the pioneer system also. My new HU came with an amp wire to hook up to a stock amp so I guess that's y it works. It's a blue wire.
Old Feb 2, 2012 | 08:16 AM
EmperorJJ1's Avatar
yup if u get the right harness then u dont have to worry abotu any of that you just install like normal other then the red acc which goes to the fusebox bypassing the stock wiring and your done
Old Feb 2, 2012 | 10:10 AM
CannonBalt's Avatar
Glad to see you got it working!
Old Mar 24, 2014 | 09:09 PM
06boosted2.0's Avatar
Cannonbalt did you just splice into the GMLAN Serial Data wire or did you remove it from the connector all together?
Old Mar 25, 2014 | 01:47 AM
EmperorJJ1's Avatar
you shouldnt splice into it but you dont need to remove it either. just leave it unconnected (assuming you are using the normal harness not the module harness)
Old Mar 25, 2014 | 08:37 AM
yeah I just bought the basic turbo wiring harness and just trying to figure out where to run the accessory wire without using the fuse box?
Old Mar 26, 2014 | 02:11 AM
EmperorJJ1's Avatar
there is no where else to run it. I mean not easily... the gm lan is data not 12v acc so taping that would never get your radio to turn on (and opens a whole bunch of problems if you put power to it) You dont have to run it to the fuse box you can tap any 12v acc wire but you want to make sure its something like an accessory not main function of the car and that whatever you are tapping can handle the additional load unless you are wiring up a relay
dennis69
Oct 20, 2015 07:39 AM
agentirons
Oct 16, 2015 02:11 AM
justinchinn
Oct 2, 2015 12:18 PM
metroplex
Sep 27, 2015 07:48 AM
