Alarm ?
Old Jan 5, 2009 | 02:08 AM
FASTL61's Avatar
Alarm ?
okay i have an alarm and i was wondering if there is a wire for the headlights in the fusebox inside.reason bein i want my headlights to flash when i arm/disarm instead of the running lights.any input is greatly appreciated
bump anyone know?
Old Jan 5, 2009 | 12:34 PM
FASTL61's Avatar
Old Jan 5, 2009 | 12:50 PM
TRANSAM197781's Avatar
just a sugestion you could probably tap off the headlight switch maybe someone else will chime in with some info
Old Jan 5, 2009 | 01:47 PM
FASTL61's Avatar
ya i was hopin there was a wire near the alarm module which is in the fuse area inside the car
bump anyone?
Old Jan 5, 2009 | 02:48 PM
importkiller's Avatar
there is a wire in the steering column that will triger the lights, the problem is I don't have colbalt any more, I had a 2005 base cobalt coupe and i sold It. I was actualy the first person to put a car alarm on a cobalt. I will look for the post.
Old Apr 28, 2009 | 03:16 PM
Cobaltsky05's Avatar
theres a combo of buttons you can push for your lcd read out that displays your fuel econ and oil life that when you press them in the right order it allows you to make your lights turn on and off then ever or select which doors you want to unlock with the keyless or if you want to change the type of keyless entry from passive to RKE and some other cool features....
Old Apr 29, 2009 | 01:27 AM
FASTL61's Avatar
I dont have a factory alarm system
satisfied
Oct 19, 2015 12:35 AM
brickloaf
Sep 6, 2015 05:55 PM
lOwBaLt
Oct 5, 2006 09:35 PM
T Dawg
Mar 6, 2006 04:19 PM
co-yellow-balt
Apr 13, 2005 10:47 AM
