Alpine system
Old Jan 8, 2011 | 01:22 AM
EmperorJJ1's Avatar
Originally Posted by AyrtonSenna
If i use an aftermarket a/v head unit (pioneer probably), would the buttons on the steering wheel still work?
if you buy a unit that is steering wheel interface "ready" and buy a steering wheel interface
Old Jan 8, 2011 | 03:25 PM
AyrtonSenna's Avatar
Most likely, I will get the Pioneer avh4200dvd with the boston system. i hope i can still use the buttons on the steering wheel
Old Jan 8, 2011 | 04:42 PM
09sscalicobalt's Avatar
im going to leave the stock system alone till i blow something up i have usb single cd xm and bluetooth stock. then ill start ******* with it lol buts its a brand new car and i like the stock system actually
Old Jan 8, 2011 | 04:49 PM
Garret's Avatar
Alpine subs are not junk they are cheap as **** used and pound hard, just get a good amp thats where everyone cheaps out
Old Jan 9, 2011 | 01:00 AM
EmperorJJ1's Avatar
if you buy the swi-ps and install it then yes you can with that radio
Old Jan 9, 2011 | 01:01 AM
Thanks ;-)
Old Jan 9, 2011 | 05:35 AM
Ok, I've decided the system:
Unit: Pioneer AVH4200DVD (hopefully to make the steering wheel buttons work)
Front Speakers: Boston SR60 Comp. Speakers
Rear Speakers: Boston SR95
Speaker's Amp: Boston GT-475
Subs: Dual 12" Boston G312 (each 375w RMS @ 4 ohms)
Sub's Amp: Boston GT-2300 (300w RMS x 2 @ 4 ohms)
I hope it will be the best configuration possible. Looking at the prices online, it is not even too expensive
Old Jan 9, 2011 | 02:50 PM
EmperorJJ1's Avatar
are u getting the amp to possibly upgrade in the future?
Old Jan 9, 2011 | 07:09 PM
what do you mean? If i install front speakers @ 85w rms, rear speakers @ 75w rms, with amm with 4 channels @ 75w rms each, subs @ 375w rms each with a 2 channel amp @ 300w rms each, can i still eventually upgrade later on?
Old Jan 9, 2011 | 07:22 PM
Damn I'm still undecided between 3 brands. Considering that the unit will be a Pioneer AVH4200DVD, I'm undecided about the following:
Front: Boston SR60
Rear: Boston SR95
Speakers amp: Boston GT-475
Subs: Boston GT3 (two of them)
Subs amp: Boston GT-2300
Front: Alpine SPR-17S
Rear: Alpine SPR-69C
Speakers amp: PDX-F4
Subs: Alpine SWR-1243D
Subs amp: Alpine PDX-M12
Front: Kicker QS65.2
Rear: Kicker KS6930
Speakers amp: Kicker ZX650.4
Subs: Kicker CompVX 12" (two of them) 2 ohms
Subs amp: Kicker ZX1500.1
What do you guys suggest? Does any of you have some of this equipment? Can you give me some advice? Thank you so much
Old Jan 9, 2011 | 08:14 PM
  #36
EmperorJJ1's Avatar
right that amp makes 300 X2 @4 but its also rated at 1400X1 @ 2 bridged.
the reason im asking is because yes it will work stereo but you would never get full power out of the amp... long story short it isnt a bad thing but its not really optimal either
Old Jan 9, 2011 | 09:08 PM
  #37
So what should I do as far as subs setup?
Old Jan 9, 2011 | 09:30 PM
  #38
EmperorJJ1's Avatar
the subs ar efine if you want to go with those but im just saying i would look into a different amp. now u dont have to running that setup would work just fine but the GT-2125 would give u the exact same power for half the price. or the GT-2200 would give u more power to work with for cheaper as well. If i had to recommend an amp i would say the GTA-800M would be the best option for those subs since its a class D mono even thou its the "lower line"
Old Jan 9, 2011 | 10:50 PM
  #39
sexy_ss's Avatar
kicker subs(cvr/cvx), alpine deck/amp, infinity speakers. best combo ive ever used personally. rockford amps are pretty good as well
Old Jan 10, 2011 | 01:45 AM
  #40
Can i use one GTA-800M for 2 subs?
Old Jan 10, 2011 | 01:48 AM
  #41
EmperorJJ1's Avatar
yes it would give you 100w more per sub then the gt 2300 and draw less current from the car. perfect match power wise
turbochargedss2012
Sep 20, 2023 12:17 PM
Jan 12, 2016 12:01 AM
patooyee
Oct 15, 2015 05:11 PM
nathan112i
Sep 30, 2015 07:12 PM
Sep 27, 2015 08:53 PM
