Alpine system
im going to leave the stock system alone till i blow something up i have usb single cd xm and bluetooth stock. then ill start ******* with it lol buts its a brand new car and i like the stock system actually
Ok, I've decided the system:
Unit: Pioneer AVH4200DVD (hopefully to make the steering wheel buttons work)
Front Speakers: Boston SR60 Comp. Speakers
Rear Speakers: Boston SR95
Speaker's Amp: Boston GT-475
Subs: Dual 12" Boston G312 (each 375w RMS @ 4 ohms)
Sub's Amp: Boston GT-2300 (300w RMS x 2 @ 4 ohms)
I hope it will be the best configuration possible. Looking at the prices online, it is not even too expensive
what do you mean? If i install front speakers @ 85w rms, rear speakers @ 75w rms, with amm with 4 channels @ 75w rms each, subs @ 375w rms each with a 2 channel amp @ 300w rms each, can i still eventually upgrade later on?
Damn I'm still undecided between 3 brands. Considering that the unit will be a Pioneer AVH4200DVD, I'm undecided about the following:
Front: Boston SR60
Rear: Boston SR95
Speakers amp: Boston GT-475
Subs: Boston GT3 (two of them)
Subs amp: Boston GT-2300
Front: Alpine SPR-17S
Rear: Alpine SPR-69C
Speakers amp: PDX-F4
Subs: Alpine SWR-1243D
Subs amp: Alpine PDX-M12
Front: Kicker QS65.2
Rear: Kicker KS6930
Speakers amp: Kicker ZX650.4
Subs: Kicker CompVX 12" (two of them) 2 ohms
Subs amp: Kicker ZX1500.1
What do you guys suggest? Does any of you have some of this equipment? Can you give me some advice? Thank you so much
Front: Boston SR60
Rear: Boston SR95
Rear: Kicker KS6930
the reason im asking is because yes it will work stereo but you would never get full power out of the amp... long story short it isnt a bad thing but its not really optimal either
So what should I do as far as subs setup?
the subs ar efine if you want to go with those but im just saying i would look into a different amp. now u dont have to running that setup would work just fine but the GT-2125 would give u the exact same power for half the price. or the GT-2200 would give u more power to work with for cheaper as well. If i had to recommend an amp i would say the GTA-800M would be the best option for those subs since its a class D mono even thou its the "lower line"
