Battery or Alternator going??
Old Jul 9, 2008 | 09:52 AM
RedEcotecSS's Avatar
I have two 12" JL audio subs and a pioneer 700w amp. Only other things that draw power while i'm driving is a little red LED strip under my radio. other than that, i dont keep my underbody LED's on while driving. although, when i turn my radio on, even with it turned down, my lights flash and dim and **** every time my bass hits. keep in mind, my amp is not turned up but like 1/4 of the way. would this be a sign of an alternator going or do i need a high performance battery? capacitor maybe? thanks guys.
Old Jul 9, 2008 | 09:55 AM
lewisb13's Avatar
From: Home: Utica, MI Current Location: Mobile, Alabama
Doesnt matter how much your amp is turned up. Get a capacitor, 1+ farad and Optima battery.
Old Jul 9, 2008 | 10:00 AM
alright man thanks. if i can make myself stop buying **** for my bike for a month and save my money. lol
Old Jul 9, 2008 | 10:03 AM
originaladrian's Avatar
with my cap and deep cycle i have no more diming. also make sure to do the "big 3" it makes a huge difference
(if it is ur alt, ill see u a spare for cheap)
Old Jul 9, 2008 | 10:08 AM
i'm pretty much a noob to audio things..
so what type of cap and where did you get it?
also what is the "big 3"?
Old Jul 9, 2008 | 10:17 AM
the big three is much bigger better wire from-
1. negative from ur bat to ground
2.Alt to battery
3. block to ground.
tht alone will prob cut ur dimming in half.
as far as other things like caps and batteries u have a few options depending on ur budget.
If you do the big 3 and get a decent cap u should be fine but i highly recommended replacing the stock battery with something more reliable.
Last edited by originaladrian; Jul 9, 2008 at 10:17 AM. Reason: Automerged Doublepost
Old Jul 9, 2008 | 10:18 AM
2.Alt to battery
3. block to ground.
holy **** that sounds like a good bit of work. well, everything except the battery to ground wire. what gauge did you use?
Old Jul 9, 2008 | 10:29 AM
guage2 for my whole car but tht might have been overkill.
(it also may not have becuase i used wire by "scosh" and i dont think thts the best quality.)
its not that much work, once u finish u will laugh becuase its really not that bad.
also, if ur going to do it, do it right and u wont have to worry about it ever again.
make sure all ur main power sources are close together. ur cap can be a little bit away from ur bat but make sure the cap is right next to ur amp.
Last edited by originaladrian; Jul 9, 2008 at 10:29 AM. Reason: Automerged Doublepost
Old Jul 10, 2008 | 05:22 AM
EmperorJJ1's Avatar
ud be surprised that scosche wire os actually pretty good
Old Jul 10, 2008 | 05:24 AM
HackAbuse's Avatar
I did "The Big 3" with 0/1 Gauge wire.
Hahah, Wowww was that fun trying to snake that ******* wire under the carpet and thru the center console.
Old Jul 10, 2008 | 09:49 PM
EmperorJJ1's Avatar
lol i didnt run it thru the center console... **** that although i did have the carpet seats and everythign removed when i was running wire
DarrenGC
Dec 24, 2021 01:55 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
justinchinn
Oct 2, 2015 12:18 PM
grampss
Sep 27, 2015 08:51 PM
c_m_shooter
Sep 27, 2015 04:40 PM
