Blown system Or just Loose wire?
Old Apr 23, 2008 | 04:48 PM
Sharic SS's Avatar
Alright i just now started to have a problem with my System. 1600 watt amp with two 12s. When ever i turn the key over You hear a Thump Thump from the Subs then no sounds comes out of it. Ive tried to turn it on and off a few times and still does it. It seems it wants to only work every other day. I was Figuring a Loose wire due to i still have the stock HU. Any Thoughts or advice?
Old Apr 24, 2008 | 02:35 AM
EmperorJJ1's Avatar
doesnt quite sound blown but it could very well be the tinsil leads (sorta doubting it)
only way is to test. Invest in a multimeter... check sub ohm, see if ur getting good voltage from power and remote. test continuity of amp ground. test RCAs. test amp output
Old Apr 29, 2008 | 11:10 PM
blackcopper's Avatar
Turn on thump?
Try putting a 1000 ohm resistor in line with the remote turn on. A lot fo aftermarket amps give you a turn on thump when you use a factory radio. Try this and let me know if it doesnt work. Each case is different.
Old Apr 30, 2008 | 12:08 AM
EmperorJJ1's Avatar
but no sound after... turn on pop isnt the issue here
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
dennis69
Oct 20, 2015 07:39 AM
Tupp
Sep 30, 2015 08:18 PM
ThoR294
Sep 28, 2015 05:31 PM
jmelton327
Sep 26, 2015 10:04 PM
