changing out the stock sub
Old Sep 25, 2009 | 12:08 AM
G5GT2007's Avatar
i was wondering can i change the stock sub out of my g5 and put another 10inch sub in the stock box and have it work? i have a 10inch sub in my blazer and want to put it in the G5.
Old Sep 25, 2009 | 11:08 AM
Pontiac.G5's Avatar
a guy on the site did this AWHILE back i tried looking for it but couldn't find it... wat you need is a shallow sub. like the ones that people put under the seats in their trucks.
Old Sep 26, 2009 | 01:37 AM
EmperorJJ1's Avatar
x2 dont expect a giant upgrade either
Old Oct 1, 2009 | 05:32 PM
Dom3sticBeast's Avatar
So the box is the limiting factor? I've been wanting to do this for a while with a better 10" shallow sub and a more powerful amp. I really like the stock enclosure because of it's size, out of the way clean look.
What about adding that "fill" that helps mimic a slightly larger volume? Does it only work on sealed enclosure or is it likely all hype?
Old Oct 2, 2009 | 04:49 AM
EmperorJJ1's Avatar
it works on almost any enclosure. doesn't make a big difference but it does make a difference (and its cheap)
Old Oct 2, 2009 | 06:29 PM
SS SCHGD's Avatar
If you are going to change the Amp for it too, then you can go with a different 10" shallow mount sub, but using the stock amp with a aftermarket sub won't help a whole lot.
I have a Rockford Fosgate P3 shallow and am feeding it from a external amp (about 300 RMS) and it is a big upgrade over stock.
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
Jan 12, 2016 12:01 AM
Oct 13, 2015 09:32 PM
MrInsanityWolf
Sep 29, 2015 04:54 PM
