changing out the stock sub
i was wondering can i change the stock sub out of my g5 and put another 10inch sub in the stock box and have it work? i have a 10inch sub in my blazer and want to put it in the G5.
a guy on the site did this AWHILE back i tried looking for it but couldn't find it... wat you need is a shallow sub. like the ones that people put under the seats in their trucks.
So the box is the limiting factor? I've been wanting to do this for a while with a better 10" shallow sub and a more powerful amp. I really like the stock enclosure because of it's size, out of the way clean look.
What about adding that "fill" that helps mimic a slightly larger volume? Does it only work on sealed enclosure or is it likely all hype?
If you are going to change the Amp for it too, then you can go with a different 10" shallow mount sub, but using the stock amp with a aftermarket sub won't help a whole lot.
I have a Rockford Fosgate P3 shallow and am feeding it from a external amp (about 300 RMS) and it is a big upgrade over stock.
