is this correct?! HELP
Old Aug 16, 2008 | 02:10 PM
britt's Avatar
so i just ordered a new HU.
the pioneer DEH-P5000UB
and i got the metra 70-2103 wiring harness
do i need to get a fuse tap?
i have an 06 and have already checked to make sure the DIC and chimes work, they do.
Old Aug 16, 2008 | 02:12 PM
Blackout06LS's Avatar
No you shouldn't.
Just wire the harness up to the CD player. Plug and play.
Did you get the fit kit, etc.
Old Aug 16, 2008 | 06:05 PM
britt's Avatar
Originally Posted by Blackout06LS
No you shouldn't.
okay, thanks.
it just said that the harness came w/ a power wire that needed to be run to the fusebox
so i didnt know.
and yeah i got the dash kit, it came with it (from crutchfield)
Old Aug 17, 2008 | 04:18 AM
EmperorJJ1's Avatar
yes u do need a fuse tap.
Old Aug 17, 2008 | 11:16 AM
britt's Avatar
okay.
and i dont have to re-pin or anything with the metra harness correct?
Old Aug 17, 2008 | 04:20 PM
Originally Posted by britt
okay, thanks.
so i didnt know.
Then you do need one.
Should've done research on that harness.
okay.
No, just run the wire to your fuse box or run a wire to a power source and add a in-line fuse.
I ran mine to a 15A fuse on my fuse box. Can't remember exactly which one, but it was a non-critical one. Meaning if it popped I wouldn't of lost something critical.
Last edited by Blackout06LS; Aug 17, 2008 at 04:21 PM. Reason: Automerged Doublepost
dennis69
Sep 22, 2015 08:56 AM
dennis69
Sep 21, 2015 11:55 AM
Jeffwills14
Sep 6, 2015 06:52 PM
