Dimming Problem
Dimming Problem
2007 Cobalt LS
Ok, so I did the Big 3, the appropriate way, and a new battery (Kinetik HC1800)
Alpine
Two MRP-500's (500@2 ohms) to power 2 4-ohm Type R's wired for 2 ohm power
F300 (50 watts@4 for 4ohm) powering Two Type R 6.5's in the doors and Two 6x9's in the rear deck
CDA-117 Headunit
ROCKFORD FOSGATE
All wiring, 1/0 guage, 4 and 8 guage
Distribution Blocks yada ya
Problem, my d@mn lights still dim when the subs are @ +15 and the radio is all the way up +35. Now I don't plan on rolling around blasting the subs @ +15 all the time, but there are times when I want to lol. Anything else I can do? If you suggest HID's please include where you got them from, what harness(s) I need for my car and where I can get them installed. Have never done headlight installs b4
Alpine
CDA-117 Headunit
ROCKFORD FOSGATE
probably not but few systems are small enough so the stock alt does have enough power. anyway get a digital multi meter set it on dc voltage and see what its reading on the amp. then again on the battery
lol right? theres always the "frame" just outside the wheel well. its a pita to screw thru but whatever
its hard for me to tell whats actually better and whats not soly because most of the time i would redo the ground was in hopes it would fix a broken piece of equipment not necessarily because i knew the groudn i had was bad
