Dimming Problem
Old May 14, 2010 | 10:38 PM
Derk1827's Avatar
Dimming Problem
2007 Cobalt LS
Ok, so I did the Big 3, the appropriate way, and a new battery (Kinetik HC1800)
Alpine
Two MRP-500's (500@2 ohms) to power 2 4-ohm Type R's wired for 2 ohm power
F300 (50 watts@4 for 4ohm) powering Two Type R 6.5's in the doors and Two 6x9's in the rear deck
CDA-117 Headunit
ROCKFORD FOSGATE
All wiring, 1/0 guage, 4 and 8 guage
Distribution Blocks yada ya
Problem, my d@mn lights still dim when the subs are @ +15 and the radio is all the way up +35. Now I don't plan on rolling around blasting the subs @ +15 all the time, but there are times when I want to lol. Anything else I can do? If you suggest HID's please include where you got them from, what harness(s) I need for my car and where I can get them installed. Have never done headlight installs b4
Old May 15, 2010 | 12:54 AM
EmperorJJ1's Avatar
where is the batt ground?
Old May 15, 2010 | 03:23 PM
Derk1827's Avatar
Right where the factory one was, next to the battery on the left
Old May 15, 2010 | 03:40 PM
knighthawk's Avatar
might want to look into a capacitor.
Old May 15, 2010 | 09:45 PM
EmperorJJ1's Avatar
cap might help but idk... i would measure your voltage and see how much its dropping. may need to move the battery ground
Old May 17, 2010 | 09:11 PM
Derk1827's Avatar
Don't know how to do that, I don't think my alt isn't pushing out enough power...but thats jus a hunch
Old May 17, 2010 | 11:01 PM
EmperorJJ1's Avatar
probably not but few systems are small enough so the stock alt does have enough power. anyway get a digital multi meter set it on dc voltage and see what its reading on the amp. then again on the battery
Old May 18, 2010 | 11:29 AM
brickloaf's Avatar
Is there a better spot than the stock ground that's close? I've had mine in a variety of places throughout the years
Old May 18, 2010 | 11:39 AM
EmperorJJ1's Avatar
lol right? theres always the "frame" just outside the wheel well. its a pita to screw thru but whatever
its hard for me to tell whats actually better and whats not soly because most of the time i would redo the ground was in hopes it would fix a broken piece of equipment not necessarily because i knew the groudn i had was bad
Old May 21, 2010 | 12:48 AM
Derk1827's Avatar
Yea, I'm gonna try and ground it in a different spot, I just need more money to get more 1/0 wiring to do it
turbochargedss2012
Sep 20, 2023 12:17 PM
yellow dragon
Sep 28, 2015 09:49 PM
Iceberg
Sep 28, 2015 01:31 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
