Door Locks Not Working Correctly
Old Jan 26, 2012 | 02:05 PM
ccoulson's Avatar
Car is a 2006 SS 2D Coupe.
Problem: When I use my key fob to unlock/lock the car, the 'alarm' aspect functions correctly without issue (headlights flash when unlocked, alarm light on dash illuminates when locked), but the door locks do not actuate up or down, and there is no noise suggesting that they are attempting to work.
Some notes:
- This issue arose at the same time with both doors. I'd assume that odds are that both actuators would not fail at the same time, so it must be something else.
- Fuse in-cabin is in good working order.
- Awhile ago, I actually removed the dash trim that houses the switch for the trunk lid-- I detached the button's harness from the trim piece, put it back together exactly as taken apart, and the trunk lid release stopped working. Did not respond using the fob, and the button seems to be 'pushed in' all the way. I've just been using the key-- no big deal.
Any ideas or suggestions would be fantastic. I'm firmly standing by the fact that I feel that the issue is not related to the actuators.
Old Jan 26, 2012 | 10:32 PM
c4w18's Avatar
any work done on your car recently?
Old Jan 26, 2012 | 11:00 PM
turbosmart4's Avatar
on trunk lid problem, have u tried pressing the button all the way?
ccoulson's Avatar
1) Nope, not without me knowing about it. I did swap a radio, though. Car was off with the battery disconnected the entire time. Nothing shorted.
2) The button feels like it's stuck inward, so it can't be pushed any further.
Old Jan 26, 2012 | 11:08 PM
the trunk release switch is broken..most likely
Old Jan 27, 2012 | 09:18 PM
c4w18's Avatar
you probably lost the rubber surround that has the contacts in it...take the switch apart again
Old Jan 28, 2012 | 11:49 AM
ccoulson's Avatar
Would the trunk release button also cause issues with the door locks malfunctioning?
Old Jan 28, 2012 | 07:37 PM
c4w18's Avatar
different circuits....both BCM controlled though from what I remember they're on the same plug.
Old Jan 29, 2012 | 07:55 PM
ccoulson's Avatar
So I'm assuming the signs are pointing to both actuators going bad.. Just seems really odd to me...
Old Jan 29, 2012 | 09:50 PM
c4w18's Avatar
yea i doubt they're going at the same time....someone with the circuit might be screwy.
RaginChopsuey
Oct 27, 2015 01:27 PM
agentirons
Oct 16, 2015 02:11 AM
SSLOW06
Oct 1, 2015 07:21 PM
Trav3480
Sep 28, 2015 02:46 PM
