Dropping resistor? iat2 on 2.4 help
Looking for some help from people that have more electronics knowledge than me, which could be everyone lol. Car is a 07 balt ss 2.4 with m62.
I want to hookup my aeroforce interceptor's(vers. 3.4) analog 1 input to my 2.5bar MAP sensor iat2 output to get post supercharger temps(iat2), since the 2.4 cannot read this through the ecm. Aeroforce says I need a dropping resistor to make this work. So I suppose the MAP sensor must send out a higher voltage signal than what the aeroforce was designed for , which is 0-5V. Anyone know what size dropping resistor would be appropriate for this conversion, and where the best place to pick one up would be? Thanks!
find out some more exact info and i can give you some color codes for what OHM resistor you may need!
more info please! i can give you some color codes on resistors of the OHMs you may need!
