Dropping resistor? iat2 on 2.4 help
Old Jul 3, 2009 | 06:07 PM
mtbrent's Avatar
Looking for some help from people that have more electronics knowledge than me, which could be everyone lol. Car is a 07 balt ss 2.4 with m62.
I want to hookup my aeroforce interceptor's(vers. 3.4) analog 1 input to my 2.5bar MAP sensor iat2 output to get post supercharger temps(iat2), since the 2.4 cannot read this through the ecm. Aeroforce says I need a dropping resistor to make this work. So I suppose the MAP sensor must send out a higher voltage signal than what the aeroforce was designed for , which is 0-5V. Anyone know what size dropping resistor would be appropriate for this conversion, and where the best place to pick one up would be? Thanks!
Old Jul 4, 2009 | 12:46 AM
EmperorJJ1's Avatar
no idea man. but theres resistors as little as 0 ohm and as big as, well big so id find out from them
Old Jul 4, 2009 | 10:24 PM
ctcsoccer7's Avatar
find out some more exact info and i can give you some color codes for what OHM resistor you may need!
more info please! i can give you some color codes on resistors of the OHMs you may need!
patooyee
Oct 15, 2015 05:11 PM
Tupp
Sep 30, 2015 08:18 PM
Dylan Johnson
Sep 30, 2015 08:57 AM
grampss
Sep 27, 2015 08:51 PM
