factory Nav
Old May 24, 2010 | 10:50 PM
1971/2009 Chevy's Avatar
factory Nav
I just searched through here and i couldnt find any threds on swapping in a GM nav unit. All i can find is aftermarket. i want to keep the factory look and i like the chevy splash screen that alot of them have on start up. I have an 09 ss/tc with xm/onstar if that matters, any help would be awesome
Old May 25, 2010 | 12:17 AM
EmperorJJ1's Avatar
very very doubtful... my kenwood has a re XXX splash screen (you can put a bowetie if ud like)
i know its not the same but
Old May 30, 2010 | 08:07 PM
warrenb213's Avatar
so long as the pins match up, and the it can still interface the gm vin updating deal within the deck, i don't see why i swap of that stock deck wouldn't work.
was the very thing i had originally looked at doing prior to saying **** it and pwning 98% carpc status hahaha. :-P even if it doesn't, some folks these days still know how to make circuits and stuff to correct the timings and offsets of the data for data to pass proper.
honestly, unless your getting that deck for under 100 bucks and already know the layouts gonna be right. if your paying 600+ for it u'd be better off doing a cheaper mini-itx/matx carpc setup. then you'd have a setup for today and the expandability for tomorrow. all with the power and development capacity of the largest modification community(software) at your disposal.
Old May 30, 2010 | 11:49 PM
07blackss86's Avatar
I mean if you want something that has a true factory look, then you might want to check out the Rosen units. Not sure if they have them for the Cobalt, but I did a couple in some Acadias and they were pretty nice units. Retained all OEM functions: rear seat entertainment, factory amps, steering wheel controls, xm,etc. A bit pricey though and the few I have done had no RCA preouts which may not matter to you but to me it's a big thing.
Old May 31, 2010 | 02:49 AM
EmperorJJ1's Avatar
rosen is nice... none for cobalts thou.
Old May 31, 2010 | 03:05 AM
Nighthawk243's Avatar
Your best bet is an aftermarket unit. Just get a very conservative one. I doubt any of the ones from the Corvette or Cadillac models will fit without major modification.
Old May 31, 2010 | 07:43 PM
2.2balt's Avatar
I doubt very much they would interface at all. As far as I know you can't swap radios from other models into a different model.
Old May 31, 2010 | 08:03 PM
EmperorJJ1's Avatar
well assuming the computer nonsense works you have to also take in to account the actual shape of the radio
Old May 31, 2010 | 08:11 PM
warrenb213's Avatar
which is typically double din in the case of their stock nav decks......
honestly i remembered reading, if u got a unit from ebay which was from korea,china,europe, and it came from a vehicle with the same ecm, u could get it to work.
Old May 31, 2010 | 08:39 PM
EmperorJJ1's Avatar
right what i meant by shape was curvature.
same vehicle from abrod sounds promising thou
Old May 31, 2010 | 09:18 PM
thanks for all the input guys
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
importkiller
Sep 30, 2015 07:18 PM
nathan112i
Sep 30, 2015 07:12 PM
cw383
Sep 30, 2015 12:41 AM
