Get the system Hooked Up
Got the system Hooked Up
As the title says I just got my subs working. Had some trouble getting the right parts and time to do it.
Subs
2 Rockford Fosgate Punch 12s (RFP3412)
Amp
Rockford Fosgate Punch P300-1
(Amp Pic taken from my last car)
Subs
Amp
Look into some dd 1508 subs or some SA8s (Digital Design or Sundown Audio)
I was never a fan of large subs. Time after time Ive seen well setup high powered small subs do just as well if not better than larger subs.
In the local outlaw class I saw 2 12 inch DD subs getting burped at 3000 watts each in a 3rd order setup beat out 2 kicker 18 inch subs getting roughly 10,000 watts each by almost 3 decibels. DD setup was Mach1 audio out of washington mo. Kicker setup was SB audio out of Union Missouri. DD setup was in an 80s Volvo. Kicker setup in a 2 door blazer with the back windows replaced by sheetmetal and welded solid.
Very very cool setup!
im not a fan of the amp being mounted on the box. i did that with my old setup and it vibrated the **** out of the amp. im surprised it didnt break the boards in the amp cus you could hear the **** in the amp vibrating when your head was near the trunk.
that was in my Saturn, currently i have it on the side...idk where else to put it
