Get the system Hooked Up
Old Feb 5, 2011 | 02:25 PM
keiserX13's Avatar
Got the system Hooked Up
As the title says I just got my subs working. Had some trouble getting the right parts and time to do it.
Subs
2 Rockford Fosgate Punch 12s (RFP3412)
Amp
Rockford Fosgate Punch P300-1
(Amp Pic taken from my last car)
Old Feb 5, 2011 | 03:13 PM
brickloaf's Avatar
looks good but if you point em towards the rear of the car it will be louder.
Old Feb 5, 2011 | 03:18 PM
mkulrey13's Avatar
Looks good mike. I couldnt add the extra weight to my car but i do miss my subs
Old Feb 5, 2011 | 05:23 PM
keiserX13's Avatar
Ive had them both ways and i like the way they sound facing forward LOL
Plus then there protected from stuff in the trunk
Old Feb 5, 2011 | 05:38 PM
CordiaDOHC's Avatar
My dd 1508 with box weighs about 20lbs more than stock and can handle enough power to hit nice and hard. 20lbs is nothing!
Look into some dd 1508 subs or some SA8s (Digital Design or Sundown Audio)
I was never a fan of large subs. Time after time Ive seen well setup high powered small subs do just as well if not better than larger subs.
In the local outlaw class I saw 2 12 inch DD subs getting burped at 3000 watts each in a 3rd order setup beat out 2 kicker 18 inch subs getting roughly 10,000 watts each by almost 3 decibels. DD setup was Mach1 audio out of washington mo. Kicker setup was SB audio out of Union Missouri. DD setup was in an 80s Volvo. Kicker setup in a 2 door blazer with the back windows replaced by sheetmetal and welded solid.
Very very cool setup!
Old Feb 5, 2011 | 05:50 PM
thedude411's Avatar
im not a fan of the amp being mounted on the box. i did that with my old setup and it vibrated the **** out of the amp. im surprised it didnt break the boards in the amp cus you could hear the **** in the amp vibrating when your head was near the trunk.
Old Feb 6, 2011 | 12:18 AM
keiserX13's Avatar
that was in my Saturn, currently i have it on the side...idk where else to put it
turbochargedss2012
Sep 20, 2023 12:17 PM
Jan 12, 2016 12:01 AM
patooyee
Oct 15, 2015 05:11 PM
OrangeCoba
Oct 1, 2015 10:00 PM
nathan112i
Sep 30, 2015 07:12 PM
