Half Of My System Installed Pics!!!!!
Old Sep 26, 2007 | 04:03 AM
cobalt_driver's Avatar
very nice. i almost went with type x's. i found a place that carried them online. ughhh i wen with kicker instead. 2 L5's 12's. with an 1800watt audiobahn amp...1200x1 at 2ohm. Its sooo loud, I need massive amounts of dynomat. My subs aren't even running at full potential. They are severely under-powered. but its cool, no strobe effect on the head lights. haha. very clean though. also, eclipse makes a very nice head unit. top of the line, for half the price. FTW. i love the setup, it soo nice. and bright!
Old Sep 26, 2007 | 11:59 AM
dc2loco's Avatar
do you hear like a loose bolt on the rear deck?
Old Sep 27, 2007 | 11:35 AM
dc2loco's Avatar
Did you snip the trunk light to wire those neons?
Old Sep 27, 2007 | 02:27 PM
black_bullet_gt's Avatar
Yeah. That pink wire you see is for my high level converter. Once I got my deck installed, I removed it.
Old Sep 28, 2007 | 03:29 PM
dc2loco's Avatar
i snipped it and connected my neons nad it doesnt work.
Old Sep 28, 2007 | 04:07 PM
0redline6's Avatar
Originally Posted by dc2loco
Ahhhh ok damn i needed someone that has a Cobalt that had subs and did'nt
dynamated it tiull after
i did mine after lol... but i just took the subs and the box and everything out lol
Old Sep 28, 2007 | 10:59 PM
drift's Avatar
Very nice box and clean install, I deffently like your setup a lot!
Old Sep 29, 2007 | 03:38 AM
yeah most deff hear a rattling. like by the 6x9's? its horrible. i think im gonna blow out my rear window bc its so loud. lol. any suggestions other than dynomat the **** outta it. lol. also, how much DM should i buy?
Old Sep 29, 2007 | 04:05 AM
EmperorJJ1's Avatar
buy second skin... trunk pack
Old Oct 3, 2007 | 11:57 AM
dc2loco's Avatar
i heard that all sound dead-enders work the best if its put in one piece, i'm looking at the rear deck and it looks like it will be pretty hard to put it in as one piece, and also should I do the top and bottum of the rear deck?
Old Oct 3, 2007 | 11:37 PM
  #36
EmperorJJ1's Avatar
vibration mats like second skin damp pro or dynamat extreme do not need to be in one piece but sound deadening barriers like second skin lux liner do.
Old Oct 4, 2007 | 11:34 AM
  #37
dc2loco's Avatar
ok thanks and should I do the top and bottum of the rear deck?
Old Oct 4, 2007 | 11:39 AM
  #38
EmperorJJ1's Avatar
i did (well most of the bottom) it s a lil extreme but helps out alot
Old Oct 4, 2007 | 11:52 AM
  #39
dc2loco's Avatar
well i am doing the bottum and basically almost done.
but the top i mean. should i do that?
Old Oct 4, 2007 | 10:48 PM
  #40
EmperorJJ1's Avatar
i did the top first and then the bottom so id say yes but its a pain to get out the rear deck
Old Oct 5, 2007 | 01:52 AM
  #41
dc2loco's Avatar
yeah what i was wondering.
what is the point of dynamating the top deck.
sorry i am a newb
Old Oct 5, 2007 | 07:41 PM
  #42
EmperorJJ1's Avatar
well the point of doing any vibration dampener is to reduce or eliminate movement along the piece its on.... example the reason you get alot of exhast noise is because the noise itself will vibrate the sheet metal on the bottom of the car... when this moves it creates a sound much like a drum or cymbal but since its not tuned it creates noise.... what a vibration mat does is have a soft layer of material (usually butly or asphalt) covered by a stiff layer (usually aluminum but on some cheaper products like edead, plastic) This helps in 2 ways... adds mass to the sheet metal makign it less likely to move in the first place and the most important is the soft layer inbetween the 2 stiff layers (one being the sheet metal) will take what movement it gets and change it into a small mount of heat causing the movement to either reduce or stop... FYI all sound deadeners and even roofing products used as soudn deadeners will add mass but usually only the better butly rubber will do a good job at stopping the movement
dennis69
Oct 20, 2015 04:49 PM
dennis69
Oct 20, 2015 07:39 AM
Oct 13, 2015 09:32 PM
justinchinn
Oct 2, 2015 12:18 PM
SSLOW06
Oct 1, 2015 07:21 PM
