Headlights only sometimes come on at night
Old Jun 2, 2013 | 11:55 PM
bchess's Avatar
Hey i have retrofit HIDs and they work great normally, but recently some nights they just won't turn on at all. Sometimes after a few minutes of driving they just randomly come on.
Turning them on automatically doesn't work, nor does using the highbeam switch.
Just wondering if anyone has ever had an issue with this, not sure if it is a problem with my daytime/nighttime sensor, some of the connections or fuses, or what.
Recent work since the issue came up was a GM deck harness replacement (not sure if relevant in anyway).
Thank you for any input.
Old Jun 3, 2013 | 12:05 AM
footballplaya3k's Avatar
Weird both are doing it, but when I had this issue one light I needed a new ballast.
Old Jun 3, 2013 | 12:11 AM
Check every plug. Sounds like you have some corrosion buildup in one of them. I wound up soddering and heatshrinking wires together because my plugs kept corroding
Old Jun 3, 2013 | 12:13 AM
chevygirl2006's Avatar
One of mine would do that and it ended up being the car's headlight harness. I had to replace it.
Old Jun 3, 2013 | 03:21 PM
bchess's Avatar
I'll check all the plugs that would have an impact on both of them, because either they both are off, or both are on, and always turn off/on at the exact same time.
Could also be my light sensor maybe, anyone have an issue with that before?
Old Jun 3, 2013 | 03:24 PM
Turbalt2010's Avatar
mine did that also.
replaced my relay in the HID harness and it worked.
Old Jun 3, 2013 | 03:31 PM
well if you are flipping the switch and they arent turning on, i wouldn't think its the light sensor
Old Jun 6, 2013 | 12:45 AM
bchess's Avatar
Went in, checked all the connections multiple times, cleaned all the ones that looked iffy, still no luck.
My CCFLs both always light up, and my turn signals also.
I don't understand why it takes them a few minutes sometimes to turn on if they ever do.
Nothing is fully broken since they will usually will eventually both turn on at the same time, I'm really confused and I haven't read anything like this before.
Old Jun 6, 2013 | 12:56 AM
Sir_Hiro's Avatar
are you running a HID Relay harness? I had this problem wiht my driver side not turning on and I had to solder new connections onto the Harness.
Old Jun 6, 2013 | 01:07 AM
bchess's Avatar
Ya I'm running a full morimoto HID kit, has a relay harness, i took it apart and cleaned it all, thought that would do the trick
Old Jun 6, 2013 | 01:17 AM
cobaltss#01's Avatar
Sounds like it could be the relays.
Old Jun 6, 2013 | 01:20 AM
Sir_Hiro's Avatar
Id say fiddle with teh connections when you start the lights on..cuz I had to fiddle with em to get the drivers side to come on until I replaced he connectors
Old Jun 6, 2013 | 01:25 AM
bchess's Avatar
I tried doing that exact thing briefly when i had all taken apart with no luck.
Starting to think my relay itself may be crapping out a bit.
They were made by mkulrey13 / buyhids / hidwerks... PMed him, he is usually good about customer service stuff so hopefully he can help me out with parts if I need them. Having no headlights make night driving / leaving town pretty much impossible so this needs to get fixed ASAP.
Old Jun 6, 2013 | 01:27 AM
wait The halo's and the turn signals don't run through the ballast, correct. if not maybe it is the ballast.
Old Jun 6, 2013 | 01:29 AM
I'm sure he'll get back to ya
Old Jun 6, 2013 | 01:49 AM
bchess's Avatar
Ya but both ballast wouldn't go out then back on at the same time.
Think the only option here that makes sense is the relay i think.
Hopefully a response tomorrow, see what he says
Old Jun 6, 2013 | 02:50 AM
Sir_Hiro's Avatar
Could be the relay as well..stickin until it heats up then lets go. Cuz itd be odd for both ballasts to go out..especially ones like Mormotio
Old Jun 6, 2013 | 03:45 PM
bchess's Avatar
Working on getting a new Mormotio relay under warranty.
Old Jun 18, 2013 | 03:56 AM
bchess's Avatar
New harness fixed it
Old Jun 18, 2013 | 05:54 AM
LS6Rally's Avatar
Same thing happened to my Morimoto harness, Water got in at the relay and corroded the wires. lights were in and out. glad you got it fixed, i know how much it bothered me!
Sl0wbaltSS
Nov 21, 2018 11:11 PM
TedSS
101
Apr 25, 2016 10:46 PM
Bluelightning
Nov 11, 2015 02:41 PM
allpro666
Oct 6, 2015 08:11 PM
